Old 06-20-2009, 07:47 AM
T.B.A.  is offline
Posts: 135  -  iTrader: (1)
Digitech GSP1101 problem
Hi all
I picked up a GSP1101 yesterday and tonight downloaded some patches off the Digitech site to install in the "User" data base, so I know how, but I keep getting this message---
" A parameter with address ID = WahMin_1_99, Position = 3 is not in the collection"
I've re-calibrated the Control 2's expression pedal thinking maybe the "WahMin" may have something to do with it, but to no avail.
Factory re-set was also tried, just in case, but-- with the same result!
Anyone else have this problem before?
Old 06-20-2009, 08:14 AM
axemanrio  is offline
Posts: 992  -  iTrader: (13)
Re: Digitech GSP1101 problem
Check what firmware version those patches were created using. Most users are on the C46 or C48 custom firmware so when they upload patches from their GSP, it will only work with the same C46/48 firmware. It's easy to update your GSP, and I'd highly recommend that because of the feature enhancements and amp/pedal upgrades.
Check http://www.mustbebeta.com/Gsp1101_Users.html for more details.
Old 06-20-2009, 08:18 AM
Did a little searching and I can confirm that updating your GSP1101 to the latest beta will fix that issue. Don't forget to backup your old patches first.
Good luck, you'll also love the new amps and OD pedals with the latest firmware.
Old 06-20-2009, 09:10 AM
T.B.A.  is offline
Red face
Thanks so much Axemanrio, I've installed the c46/c48 firmware and the X-edit zip to suit, but now I have this come up when I try and open X-edit
"Initialization error"
"A parameter with address ID = 0x3053, Position = 0
And then a few seconds later I get this---
"Unsupported bank specified
Parameter name: bank
Actual value was factory."
I have no idea
Any suggestions?
Old 06-20-2009, 09:33 AM
T.B.A.  is offline
I think I found it, looks like a problem with the desk top short cut from the previous version of X-edit.
Thanks again.
Old 06-20-2009, 09:50 AM
Oh yeah, forgot to mention that you need X-Edit 2 Beta from the same mustbebeta site. Keep your original X-Edit installation intact because the beta uses those system files to run.
digitech gsp1101
digitech gsp1101 w/control2 vaitamin7v Gear and Equipment 23 11-15-2010 01:51 PM
FS: Digitech GSP1101 Guitar Preamp/Processor Warrior Classified Ads: Guitars and Gear 1 02-14-2009 09:40 AM
FS: Digitech GSP1101 w/Control 2 $599 Shane Regal Classified Ads: Guitars and Gear 0 10-29-2008 03:29 PM
Digitech GSP1101 and Control 2 rikkbeatty Classified Ads: Guitars and Gear 0 10-17-2008 10:22 PM
TC Electronics G-system or Digitech GSP1101 - thoughts? trondulseth Gear and Equipment 14 09-17-2007 09:57 AM
