Old 03-18-2001, 03:02 PM
chris state  is offline
Posts: 49  -  iTrader: (0)
Digitech xp100 PROBLEM!!!! please helP!
My xp100 is all messed up right now. When i turned the thing on today, it went into this wierd mode where the thing jsut says "ca" or "er" or a bunch of random letters. whenever i press any button, it jsut goes to a new set of letters. there is no signal either. what do i do?
thank. this is a bad first post, but ive been reading here for a long time.
thank you
Old 03-19-2001, 01:19 AM
bduersch  is offline
Posts: 1,357  -  iTrader: (1)
If you can't do a hard reset (I don't know how to do one on an XP100, but usually there's a way to reset it by holding down a button and turing it on--you may lose any patches/settings you've saved, though), it probably needs to be taken in to a shop. I had a GSP21 and a GSP2101 that flaked out. The GSP21 had to go into the shop, but I was able to bring the 2101 back to life with a full restore.
Good luck!
--Brent
Old 03-19-2001, 01:51 AM
jem7pbk  is offline
Posts: 208  -  iTrader: (1)
My old one did that once The Ca means calibrate I pushed the pedal all the way forward then all the way back and then taped the button and it went back to normal. Try that.
Old 03-19-2001, 09:10 PM
ok, im stuck in the user presets, and i have no idea what to do?
damn thing. *******
digitech.
Old 03-26-2011, 10:10 PM
Cevincc  is offline
Posts: 3  -  iTrader: (0)
Re: Digitech xp100 PROBLEM!!!! please helP!
Howdy. I'm having a similar problem. I'm doing the Factory reset, I get Er code. Not working. So here I am...maybe you can fix in the manual. If not hmmm to da repair shop. Factory Reset/Pedal Calibrate - To reset the User programs to their factory settings and calibrate the
expression pedal, press and hold the <BYPASS/(Hold)TUNER> foot switch and apply power to the unit.
Wait until the letters rS appear in the display and release the foot switch. The display will now show: Pd
and CA , indicating that you are in pedal calibrate mode Once Pb appears, rock the pedal back and
press the <BYPASS> foot switch. When PF appears, rock the pedal forward and press the <BYPASS> foot
switch. SA will next appear in the display to confirm the pedal is now calibrated.
S
Old 03-26-2011, 10:16 PM
6fingers  is online
Posts: 3,167  -  iTrader: (0)
Reviews: 63
S
Dude it's a thread from ........................2001!!!
Do you really think he's still waiting for a reply?
Another thread digger lol
