Old 07-10-2007, 01:51 PM
Ibanut  is offline
Posts: 223  -  iTrader: (2)
DImarzio question
I have a pickup with S1 on the back . it says dimarzio pickups mage in usa also. ANy idea as to what this is?
Old 07-10-2007, 02:10 PM
LuredMaul  is offline
Posts: 764  -  iTrader: (22)
Re: DImarzio question
that is Ibanez dimarzio designed single coil pickup.
Not a bad pickup
Old 07-10-2007, 02:14 PM
Ibanut  is offline
No its a humbucker. The S1 is on the back. When I ohm the red and black I get 4.64 and with the green and white I get 4.52. its F spaced .
Old 07-10-2007, 03:02 PM
Probably a PAF PRo then
Old 07-10-2007, 04:06 PM
giannifive  is offline
Posts: 484  -  iTrader: (8)
It stands for Satriani-1 (neck), and should be a PAF Pro if I'm not mistaken.
coil pickup, dimarzio pickup, dimarzio pickups, paf pro
Do you prefer 'brand name' DiMarzios or DiMarzio/ IBZ TheJazzTerminator Polls 5 08-18-2006 06:16 PM
Do you prefer 'brand name' DiMarzios or DiMarzio/ IBZ pickups? TheJazzTerminator J-Custom, USA Custom & Prestige Ibanez Guitars 16 08-11-2006 09:27 PM
Dimarzio Evolution set question jimihendrix1117 Pickups & wiring 6 08-10-2006 02:00 AM
Dimarzio PAF Pro Question Jimbo72 Pickups & wiring 10 07-13-2006 02:29 AM
which do you prefer in your IBANEZ? duncan or dimarzio? Roadstar Pickups & wiring 18 01-17-2006 10:54 AM
