Old 11-16-2006, 01:24 PM
Coachies67  is offline
Posts: 3  -  iTrader: (0)
Smile
Disconnecting a reverb tank
Hello. I own a Laney LC50II with an accutronics spring reverb tank. When I mic and record the amp at high volumes, the spring reverb tank vibrates and rattles can be heard on the recording. I was wondering if it's safe to disconnect the reverb tank from the signal flow of the amp. I was also thinking of using a pedal reverb (like the holy grail reverb) instead of the reverb tank. Any help or suggestions would be great.
Thanks
spring reverb
Any Rivera Knucklehead Reverb players out there?? bduersch Gear and Equipment 11 10-21-2005 08:49 PM
Adding spring reverb to an amp bduersch Gear and Equipment 6 07-15-2005 09:05 PM
Any analog reverb stomp boxes out there other than Boss RV? SilverSurfer2 Gear and Equipment 4 04-15-2003 08:58 AM
Rack-mounted spring reverb? Like the Peavey ValVerb? bduersch Gear and Equipment 2 08-05-2002 07:53 PM
