Gear and Equipment
Distortion channel
Gear and Equipment
05-09-2006, 09:23 AM
RG1550GXWB-WM Ltd Edition
Posts: 42 - iTrader: (
Distortion channel
Hi! I've got a Marshall MG100DFX and I love its sound (with the fdd sistem that well emulates a full valve amp).
Since 1 week I've got problems with its distortion channel: I sound for a while, but then the sound come and goes (it has unbelievable decreases of volume)! I've tried with changing cables, but it isn't the problem! It cannot be a problem of all the amp, because on the clean channel it works! It cannot be a problem of the guitar, because I've put the jack in another amp and it works, so...what could be the problem?
I thank you in advance!
Find all posts by RG1550GXWB-WM Ltd Edition
05-09-2006, 03:20 PM
red5
Posts: 2,639 - iTrader: (
Re: Distortion channel
The MGs seem to be a bit cheaply made. There is either bad component in the amp or a wire that was way too thin for the current it needs to transfer that got melted (as the MG wont melt a normal wire as they don't use that much power). A toasted wire is often a cause of this. Sometimes bad transistor or capacitors as well may be the culprit, and I would normally say a bad transformer could be too but if it works with one channel and not the other, then you're good there.
red5
Find all posts by red5
05-10-2006, 03:56 AM
Thanks for the reply red5!
Yesterday evening I've tried to connect in stranger ways guitar, Bad Horsie 2 and Marshall and I've seen that connecting the wah in the send-return instead of between guitar and amp, it doesn't make that problems on the distortion channel! Perhaps I've found a solution!
I love its sound!
distortion affecting sustain how does
mega distortion or metal zone?
mxr distortion iii compare satchurator
what distortion pedal can take guitars string 10-60
stratocaster duncan custom or distortion?
My mesa nomad review - (JP settings included)
track7
Gear and Equipment
10:38 PM
Embarking on major home recording project--wish me luck!
bduersch
Recording Studio
12:44 PM
My amp is too loud. What can i do?
Bladerunner
Gear and Equipment
04:03 AM
What should I do?
IbanezPrestigeBoy
Gear and Equipment
02:41 AM
Probs with clean channel on Tremoverb - only comes out low v
trapzilla
Gear and Equipment
05:38 AM
01:08 PM
