Gear and Equipment
Distortion sounds - Need advice
Gear and Equipment
07-30-2001, 10:06 PM
carlos seo
Posts: 503 - iTrader: (
Reviews: 5
In my quest for perfect tone, I've now found the clean sound I want: JEM into a Fender amp with a tape echo and
volume pedal
in the FX loop (plus the excellent Fender reverb).
Now I'm trying different combinations to get a good distortion tone using the SAME amp. The Fender drive channels aren't that great for what I want (something like Steve Morse's sound in Deep Purple), so I would like suggestions for a
distortion pedal
-- for DISTORTION use, not lead boost!
Thanks!!
carlos seo
Visit carlos seo's homepage!
Find all posts by carlos seo
07-30-2001, 10:21 PM
jay ratkowski
Posts: 2,273 - iTrader: (
Reviews: 3
Distortion sounds
You will probably think I'm nuts...
But check out one of the old Marshall Shredmasters... they are neat.
DEFINATELY check out a Fulltone pedal of any sort... preferably all of them.
jay ratkowski
Visit jay ratkowski's homepage!
Find all posts by jay ratkowski
07-30-2001, 10:48 PM
Josh Blagg
Posts: 340 - iTrader: (
Distortion sounds
First off, I wouldn't try looking for a lead tone out of a Fender amp unless it's one you can get to start breaking up a lot. *However, if you do this, then you've lost your
clean tone
You can still get distortion, but I would tend to think it would be for psychadelic lead or rhythm playing. *Try some fuzz units, especially something by Fulltone or an old Fuzz Face.
Josh Blagg
Find all posts by Josh Blagg
07-30-2001, 10:49 PM
Josh Blagg
Distortion sounds
By the way, which Fender amp are you using?
Josh Blagg
07-31-2001, 11:01 PM
rgr
Posts: 1,791 - iTrader: (
Distortion sounds
Wow, I agree with Jay, the old Shredmasters are pretty good distortion generators, not alot of output but they do sound good. *I also like the old Ibz MS-10 Metal Chargers, more of a distortion pedal than a "metal" pedal.
-R
rgr
Find all posts by rgr
07-31-2001, 11:55 PM
jay ratkowski
Reviews: 3
Distortion sounds
Wait, someone agrees with me? *I change my mind. *Shredmasters suck! *Hahaha. *Kidding kidding.
What amp are you using anyways? *That might help find a distortion box that will match it.
jay ratkowski
08-01-2001, 12:12 AM
Jesse Greenawalt
Posts: 39 - iTrader: (
Distortion sounds
I like the
Boss Metal Zone
(but no OTHER Boss fuzzes that I've heard, strangely enough)
Tube screamer with the hot switch is pretty good - the TS-7. *Still not MASSIVE gain, though.
I also dig the DOD "super american metal" - the one with 4 knobs. *No subtlety - it's metal. *But a GOOD kinda metal, IMO... *But it does dominate the tone. *You might be able to get a used one cheap.
Jesse Greenawalt
Find all posts by Jesse Greenawalt
08-01-2001, 12:45 AM
carlos seo
Reviews: 5
Distortion sounds
I'm using an old Roc Pro 700 (it sucks, I know...) for now. I'm getting a CyberTwin or an AVT in the end of the year.
Here's what I have:
- BOSS DS-1: great as a lead boost, suck at rhythm distortion.
- Ibanez TS-808: same as above, except if you like that SRV tone (I like it, but I want something like
Steve Morse
for now).
- Zoom 505 II: too artificial
Maybe I'll try an EQ after one of these pedals, but I don't want too many of them in my signal chain. I'm not even using a wah anymore!
Please, continue submiting your sugestions! Thanks!
PS- NO METAL TONES ARE DESIRED! Thanks!
carlos seo
08-01-2001, 12:48 AM
jay ratkowski
Reviews: 3
Distortion sounds
Trust me, the Shredmaster, as metal as it sounds... does NOT get you a metal distortion tone... it is more of a warm rythm sound without all that much gain.
jay ratkowski
08-01-2001, 05:35 PM
rgr
Distortion sounds
I agree, the Shredmaster or the MS-10. *The Metal Zone is way too buzzy to my ears. *
-R
rgr
08-01-2001, 06:53 PM
AJ Love
Posts: 119 - iTrader: (
Distortion sounds
either an Ibanzez TS-9 tubescreamer modded to 808 specs or a Crowther Hotcake
AJ Love
Visit AJ Love's homepage!
Find all posts by AJ Love
08-01-2001, 07:40 PM
jay ratkowski
Reviews: 3
Distortion sounds
From my limited understanding, the Hotcake is not a distortion unit, but just a signal boost/enhancer... the little bit I've heard of it makes it sound like a fabulous unit... but I don't think it's intended as a distortion unit (unless there is more than one Hotcake out there?)
jay ratkowski
08-02-2001, 01:16 AM
carlos seo
Reviews: 5
Distortion sounds
Hmm... I think I'll try the Shredmaster. And maybe the TS-9 reissue too (I don't like taking my TS-808 to gigs...there lot of bad people out there that would kill for one...).
I'll give you my thoughts about them ASAP...
carlos seo
08-02-2001, 05:10 AM
AJ Love
Distortion sounds
the Hotcake is not a distortion unit or a signal boost but is an overdrive
I have one and its working very well in terms of pushing the amp into faster overdrive mode and giving a little extra sustain and overdrive tone
haven't used it with a Humbucker
equipped guitar
yet though, so I don't know if it'll be as good with Humbuckers or if that'll even make a difference, but with *single coils its great (I'm using a Telecaster, saving up for a 7VWH)
AJ Love
08-02-2001, 02:17 PM
Josh Blagg
Distortion sounds
Choosing a unit such as a Metal Zone or anything of the like is going to create some very sharp sounding distortions with a clean amp, especially if it is solid state. *Your waveform is being massively amplified and clipped, which takes a lot of the tone characteristics away and produces a buzzing type of distortion.
Josh Blagg
boss metal zone
clean tone
distortion pedal
equipped guitar
eric johnson
input jacks
marshall jtm
power amp
steve morse
super overdrive
volume pedal
distortion affecting sustain how does
mxr distortion iii compare satchurator
what distortion pedal can take guitars string 10-60
how do you get your amp to the brown sounds
What amp sounds good with the Jemini pedal?
07:29 PM
