Old 01-22-2006, 07:19 PM
ric232  is offline
Posts: 82  -  iTrader: (0)
Do Pedals Mess Up the Sound of Good Amps
I'm thinking of getting a Mesa Lonstar Special. It's the perfect size and wattage (30W) for my home playing. I don't want anything louder. The only problem is, I sometimes like to play high-gain stuff, so I'll probably being running a Boss DS-1 through it occasionally. Does this take away from the rich sound of a good tube amp and make it sound more like a solid state amp?
Old 01-22-2006, 08:20 PM
waylay00  is offline
Posts: 3,763  -  iTrader: (10)
Re: Do Pedals Mess Up the Sound of Good Amps
Not necessarily. Steve Vai uses his DS-1 as a boost for his Carvin's real tube saturation and it sounds great. Think of these pedals (ie DS-1, TS-9, etc) as more of boost pedals and not as complete sound alteration pedals.
Old 01-22-2006, 08:30 PM
red5  is offline
Posts: 2,639  -  iTrader: (0)
If you want tube distortion get a Soldano Supercharger or something to boost up your gain. So if you don't like the sound of SS pedals, there are options!
Old 01-23-2006, 05:04 AM
wallie!  is offline
Posts: 352  -  iTrader: (0)
yeah dont run a cheap FX board through a good amp, sounds terrible (korg ax10G)
Old 01-23-2006, 12:03 PM
Gresh  is offline
Posts: 1,416  -  iTrader: (10)
Basically, I think that pedals should be used like condiments...a little here and there makes things taste just a bit better, but too much ruins everything.
As far as messing up a good sounding amp, I'd stick to high quality stuff to minimize tone loss in the signal chain. Try to find true bypass pedals, and even if you've got that favorite old AD-9 analog delay that isn't true bypass, people like Robert Keeley can mod it into being a true bypass effect...cool stuff.
Old 01-23-2006, 12:19 PM
Chris From Singapore.  is offline
Posts: 462  -  iTrader: (0)
I agree totally with Gresh.
It's a good tube amp, don't mess things up by sticking something low end in front. IMHO the DS1 really sucks as a boost pedal. Vai's DS1 on the other hand is modded by Keeley, I'm sure there's some form of distinct difference. I've tried a stock DS1 as a boost and it sounds horrible.
A better choice would be a dedicated boost pedal in contrast of a distortion pedal per se.
Do check out the gear by Xotic Effects. RC and AC booster is the way to go.
Here's a video of Scott Henderson demo'ing the pedal, on clean and the dist channel of his Custom Electronics Amp.
http://www.prosoundcommunications.co...son/index.html
The RC/AC is the next on my quest to become a full fledged pedal slut.
Chris.
Old 01-23-2006, 02:20 PM
ric232  is offline
How about the Vox Cooltron pedals? Are they any good or just a gimmick?
Old 01-23-2006, 07:27 PM
red5  is offline
Gresch said it. Don't let the pedals take over your tone
Old 01-24-2006, 09:44 PM
Al M  is offline
Posts: 551  -  iTrader: (0)
Chris.
As far as I'm aware vai uses a normal DS-1 and only used the keeley for alive in an ultra world!
Old 01-24-2006, 10:36 PM
ChopTart  is offline
Posts: 1,390  -  iTrader: (1)
IMO a DS1 doesn't do enough to your tone to make it totally change your sound anyway. It just "colours" it, if you catch my drift.
Old 01-24-2006, 10:40 PM
Drew  is offline
Posts: 4,538  -  iTrader: (4)
Trust me - if you need more gain than a Lone Star has on tap, you have issues. A different type of gain, maybe - i passed simply because the Nomad I was also demoing could do more of a contemporary "chunk" rhythm - but that thing is plenty saturated, and has an ungodly clean channel, too.
Old 01-24-2006, 10:52 PM
ElectriK  is offline
Posts: 150  -  iTrader: (1)
Get a Visual Sound Jekyll and hyde. Problem solved. Thank me later
Old 01-25-2006, 09:45 AM
ric232  is offline
You're the first person who has said that. Others who have the amp have said it is not a metal amp at all. I'm not looking for a purely metal amp, I just like to play the heavy stuff once in a while for fun. I currently have a Vox AD50VT Valvetronix that has a NUMETAL setting which I have a lot of fun with on occasion.
Old 01-25-2006, 01:41 PM
Dylan7620  is offline
Posts: 636  -  iTrader: (1)
by high gain you mean like metal style playing? i know the LSS is capable of great rock distortion. and i'm pretty sure the LSS has almost the same amount of gain as the DS-1, just better. if you need a real high gain i'd sugest somthing like the soldano supercharger or a mesa v-twin.
Old 01-28-2006, 12:22 PM
Screaming Solo  is offline
Posts: 50  -  iTrader: (0)
trust me, Vai uses a stock DS-1
i did however mod mine to keeley ultra specs and it sounds great although i think i perfer it more of a stand alone pedal than to use it as a booster, but it works either way
if i crank my marshalls (DSL401) clean channel and turn the pedal on it actually sounds quite a bit like the OD channel on the amp onlythe bass is tighter and the sound is more compressed
but i don't use any compression so the added compression from the pedal adds quite a bit to my sound
the stock DS-1 isnt bad, but there are like 1-2 spots on that pedal where you can get a good tone you have to mess with it a bit. Modded the usable tonal range is much improved, you don't need very exact settings to get it to sound great
boost pedal, distortion pedal, overdrive pedal, scott henderson, solid state amp, steve vai, tone loss, tube amp, tube distortion, tube saturation
How good will a new sound card be, what to get? themaidenmaniac Recording Studio 15 01-15-2006 07:15 AM
Mesa Nomad 45 2x12: thoughts and sound clip Drew Gear and Equipment 16 06-07-2004 05:29 PM
Double Edge - How good does it really sound Jay Satriani Other 7-string Guitars 11 09-11-2001 11:43 AM
rosewood guitar - would it sound good? Karmann Other 6-string Guitars (non-Ibanez brand) 9 06-15-2001 01:32 AM
Will Paf Pro's in a 7VWH sound good? - Can I also swap the g ashlock JEM and Universe Guitars 2 06-07-2001 05:07 PM
