Re: Double Edge Pro question
You named most of the problems. Rich is always mentioning screwing up the radius as well. If you can't set it normally with reasonable action, then you have something else wrong with your setup. Of course, if it makes you happy, use it that way. I'm not sure if it will cause any significant extra wear to the knife edges. Rich would also be a good source for bridges or parts. Check out his tech setup section while you are there. Click the swirly banner at the top of the page.
