Old 09-16-2009, 11:54 PM
bluffalo  is offline
Posts: 73  -  iTrader: (0)
Edge design fault & Kramer
In the untold story Ibanez book, it mentions that there was a design flaw with the nut with Ibanez's Edge interpretation of the OFR, and that Kramer didn't want Ibanez to find out, but Mr Floyd Rose pointed it out to Ibanez.
Anyone know more details about what the problem was?
Old 09-17-2009, 12:04 AM
Rich  is offline
Re: Edge design fault & Kramer
What's wrong with this picture
Old 09-17-2009, 12:27 AM
jemmaniac  is offline
Posts: 145  -  iTrader: (0)
Reviews: 10
what's with the B-string?
and the pink lines on the headstock?
or are the hex sizes in standard?
maybe the huge gaps between the locking nuts?
Old 09-17-2009, 12:38 AM
Rich  is offline
Too bad you edited.
Old 09-17-2009, 12:45 AM
Reviews: 10
Too bad you edited.
was i right the first time?
i've seen them both ways but i wasn't positive with that answer..
Old 09-17-2009, 01:25 AM
bluffalo  is offline
Was it just really as simple as tightening the locks the wrong way around? I saw it too, but I thought it must have been something more than that.
Cool, thanks for the answer!
I too, was looking at the b string thinking something was causing that, but the rest of the pictures just show its just a normal broken string.
Old 09-17-2009, 01:32 AM
Rich  is offline
The pads were cast with the curve on the bottom in the wrong direction.
Old 09-17-2009, 01:35 AM
bluffalo  is offline
oh okay! awesome, thank you!
Old 09-17-2009, 06:48 AM
nuno  is offline
Posts: 4,725  -  iTrader: (0)
Originally Posted by bluffalo View Post
...and that Kramer didn't want Ibanez to find out...
haha! bye bye, Kramer...
Old 09-17-2009, 08:58 AM
eruji  is offline
Posts: 81  -  iTrader: (0)
so the curve under the bottom of the pad should be in line with the strings right? and not perpendicular.
Old 09-17-2009, 11:23 AM
Ayrton  is offline
Yep...
Old 09-17-2009, 01:55 PM
Rich  is offline
The curve mates to the nut base. I should have said they cast them with the ^^^ tops in the wrong direction.
Old 09-17-2009, 02:07 PM
Ayrton  is offline
I wonder if there is any difference in the distribution of pressure based on the bevel orientation?
I doubt it matters much (if at all), but an observation nonetheless.
Old 09-17-2009, 02:11 PM
Rich  is offline
The bevel is there so that it can be higher on one side, ie. straddle the low E and A strings. If you've even tightened one of these early pads, the bolt is only biting on the high side, and it squeaks and grinds.
Old 09-17-2009, 02:15 PM
C.Thep  is offline
Posts: 3,050  -  iTrader: (18)
these bits of trivia are so cool
edge, floyd rose, kramer
Is it Steve Vai's Fault? michblanch Off-topic / Miscellaneous 20 09-30-2008 03:48 PM
Who's fault is it? Dino Off-topic / Miscellaneous 9 09-19-2008 02:44 AM
Problem with 2003 7Vwh JEM, Possibly New Edge Pro Trem Fault leonard deroma JEM and Universe Guitars 89 06-18-2007 11:57 AM
a fault in my VWH vine Courjan JEM and Universe Guitars 13 07-01-2003 09:30 AM
Kramer guitar information? - Kramer Ripley here, need serial trapzilla Other 6-string Guitars (non-Ibanez brand) 1 05-04-2001 02:13 PM
