Old 11-04-2005, 12:36 AM
adamcbest  is offline
Posts: 870  -  iTrader: (0)
effects loop question
i tried to run my amp in stereo today and it didn't see like it worked.
my mark iv has a single send and a right and left return for the effects loop. i ran the send to the mono in on my g major. then both outs from the g major to both ins on my bbe 482i. then both those outs to the right and left returns on the mark it. i'm running 2 1x12 cabs. i tried the panner feature on the g major and it seems that it just gets loud through both speakers and then soft through both speakers... its not panning. both channels of the BBE are getting signal too, but only one channel seems to be affecting the tone when i turn the knobs, so it's not that it's not sending the signal from the g major.. it seems like it's getting signal the whole way through but the mark isn't accepting it as stereo and is still only using the mono channel.. please help.. thanks
Old 11-04-2005, 09:16 AM
Avatar_k83  is offline
Posts: 61  -  iTrader: (0)
Re: effects loop question
the Mark is not a Stereo AMP, you'll need a second amplifier to send the signal there to run it in stereo (see at the manual about the satelite)
Old 11-04-2005, 09:30 AM
ohh... duh.. mesa shoulda put the effects loop section before the satellite section.. i went right to the effects loop section without looking at satellite. so how about this.. could i just add like a mesa 20/20 or 2:50 or 2:90 or whatever in my rack, send the mono signal through it, and then run two more cabinets?? i can't find anyhting about the actual mesa satellite combos, but i think i'd rather have matching cabs to the ones i have over a head and cabs for one channel and a combo for the other anyway
Effects loop volume drop in Prosonic sanchez Gear and Equipment 3 05-31-2005 09:06 PM
fender twin reverb and effects loop? SilverSurfer2 Gear and Equipment 0 02-07-2003 01:49 AM
Effects loop / Pre-amp question Gresh Gear and Equipment 5 10-04-2002 02:42 PM
Rack tuner - can I put a tuner in the effects loop? - I coul djrjems Gear and Equipment 5 02-13-2002 10:55 PM
Dilemma with effects loop. Josh Blagg Gear and Equipment 3 05-19-2001 08:11 PM
