Old 04-23-2007, 08:51 PM
kpinks  is offline
Posts: 63  -  iTrader: (0)
Effects loop question
When talking about effects loops, some are +4dB and some are 10dB. I know that the +4dB effects loops are meant for pedals and the 10dB are used with rack effects typically speaking, but can you use a rack effect in a tube-buffered +4dB effects loop successfully?
Thx
Kev
Old 04-24-2007, 04:12 PM
Rudy  is offline
Posts: 277  -  iTrader: (4)
Re: Effects loop question
I'll give this a shot. I think instrument level which is what you use with most stompboxes is -10dB. Line level which rack gear uses is +4dB. Instrument level is less hot than line level. Some rack effects like a G-major have a setting for pro or consumer which selects the input level. Rack effects are generally more accomadating to varying input levels because they ahve the ability to adjust input/output level. there are some stompboxes that have the ability to select line/instrument level also like Boss dd-20/CE-20
Effects Loop Help? Jafo Gear and Equipment 5 05-14-2006 10:10 AM
effects loop question adamcbest Gear and Equipment 2 11-04-2005 09:30 AM
Rack Effects: what are the basics? Frankie Gear and Equipment 5 06-09-2002 12:30 AM
Question Concerning FX Loops GuitarLunatic Tech: Setup, Repairs and Mods 8 05-07-2002 10:45 PM
Rack tuner - can I put a tuner in the effects loop? - I coul djrjems Gear and Equipment 5 02-13-2002 10:55 PM
