Old 09-07-2009, 05:19 PM
IBNZ_RG  is offline
Posts: 543  -  iTrader: (0)
Reviews: 18
Effects pedal ac power?????
I have an old DOD Compressor Sustainer that runs on 9v batteries. Is there any way I convert the 9v into ac power so I don't have to buy batteries all the time? It say this on the bottom: For ac operation use a 10v DC negative ground power supply. What does this mean?
Old 09-07-2009, 06:05 PM
jb4674  is offline
Posts: 4,010  -  iTrader: (0)
Reviews: 6
Re: Effects pedal ac power?????
Your DOD compressor should have an input for a power supply if that is what it says on the bottom. At that point, you can simply go to radio shack and get a 10v power supply.
Jimmy
Old 09-07-2009, 06:25 PM
IBNZ_RG  is offline
Reviews: 18
Do they look like a headphone input? Cause there is one of those next to the actual input. Other than that just a 9v thingy in the back.
Old 09-07-2009, 06:52 PM
elcid  is offline
Posts: 8,718  -  iTrader: (12)
It could look similar to a headphone input. Chances are if it isnt the input or output jack, it's the spot for the AC adapter.
Old 09-07-2009, 07:23 PM
IBNZ_RG  is offline
Reviews: 18
Thank for the help you guys. I'll ahve to check radio shack or somewhere to see if I can find an ac for it.
Old 09-07-2009, 07:58 PM
IBNZ_RG  is offline
Reviews: 18
Found an ac that barely works in my one drawer. There's alot noise in my signal not sure if it's the pedal or the crappy cable I am using since I only have one good cable.
Old 09-07-2009, 08:25 PM
elcid  is offline
Probably the cable.
Voodoo pedal power the way to go to power pedals ? Silverburst Gear and Equipment 9 06-22-2009 03:43 PM
Voodoo labs pedal power 2 plus or normal power strip? SilverSurfer2 Gear and Equipment 2 05-22-2009 12:20 AM
pedal pad MKS mps-xl NP with pedal patch and pedal power just42dave Classified Ads: Guitars and Gear 0 02-27-2009 10:33 PM
FS/FT: 1-Spot (multiple) Effects pedal power supply Demiurge Classified Ads: Guitars and Gear 3 11-07-2006 05:47 PM
power fading when effects loop engaged...Please help! texshred777 Gear and Equipment 1 03-08-2004 02:55 PM
