Gear and Equipment
effects processor questions
Gear and Equipment
09-13-2006, 12:00 AM
newbieguitarmaker
Posts: 4,030 - iTrader: (
I wanted to ask a couple questions, first, what is the main difference between the g-major and the g-force? also, is the g-force/major also a preamp? For some1 that wants a preamp and effects processor for not too much money what would you recomend? i was looking at the line6 podxt pro but im not sure how good they are.
thanks
newbieguitarmaker
Find all posts by newbieguitarmaker
09-13-2006, 03:39 AM
Sabre
Posts: 555 - iTrader: (
Re: effects processor questions
POD's are great for recording in the studio, even the cheaper one. But Vox's effects prosesser/floorboard is probably the best sounding.
Sabre
Find all posts by Sabre
09-13-2006, 06:23 AM
MetalZone
Posts: 273 - iTrader: (
newbieguitarmaker
as far as i know its only an effects processor, not a preamp. you need a seperate preamp for your distortion etc.
MetalZone
Visit MetalZone's homepage!
Find all posts by MetalZone
09-13-2006, 08:54 AM
John01W
Posts: 92 - iTrader: (
The difference is sound quality, power, better fx(I hear the harmonizer is actually quite good in the G-Force), better build quality, expansion possiblities.
Preamps in fx processors suck. Pod's suck for the most part, but are good in a pinch. Save your money and get something good, you'll appreciate it better in the long run. Get a decent fx processor a couple of pedals and a
marshall jmp
-1 on the used market.
John01W
Find all posts by John01W
09-13-2006, 10:14 AM
adamcbest
Posts: 870 - iTrader: (
newbieguitarmaker
thanks
The g-force has a harmonizer, plus additional "Drive" settings, but it also has many many more parameters that you can change for each effect. Neither are preamps. They are to be used in Effects loops or between rack preamp/poweramp setups. The G Force also allows you place any effect in any position in the effects chain, where the G major is fairly set as is. The G Force does have significantly more room to expand than the G major, the PCMCIA card slot in the G Force allow for easy software updates and patch saving/importing. I don't know if i'd say the effects are noticeably "Better", but the G-Force is simply much much more flexible of a unit. That being said, this makes the Force more difficult and time consuming then the Major. Both are fantastic units. It just depends on what your needs are. G Force runs new about 1400 USD and G Major about 400 USD
Personally, I wouldn't bother with a POD. Never much liked the sounds i could out of them. Sounded very digitized to me. I've found the Vox digital stuff is pretty decent though.
Hope this helps
adamcbest
Find all posts by adamcbest
09-20-2006, 10:39 PM
newbieguitarmaker
what about something like the rocktron prophesy or the boss gt-pro? i think once i get the money im going to try and get the g-major system and a preamp, which i still cant decide on a preamp.
newbieguitarmaker
09-20-2006, 10:49 PM
David McCarroll
Posts: 2,049 - iTrader: (
newbieguitarmaker
Rocktron stuff used to have a superb rep - at one stage every serious player had an Intellifex, dunno what's happened to them since then - the Prophesy is, I thought, a pre-amp? Boss stuff tends to sound quite "generic" to me - sort of figures when you consider that EVERYONE uses their gear!
Pre-amp wise, if money isn't really the deciding factor, you can't get much better than the
Mesa Boogie TriAxis
, which is an all-analog, all tube pre-amp but with the benefit of digital control over the storage and modification of presets - I've used a TA for about four years now, and they really do sound amazingly good - the G-Major , which I added about three months ago is probably the best $400 I have ever spent - other than intelligent
pitch shifting
, there is basically almost nothing this little gem won't do (the G-Major DOES do pitch shifting and harmonising, it won't however change majors and minors according to the scale you are playing, which apparently the G-Force will do).
Don't forget to play live, you need a power amp to go with your pre-amp, unless you trust the sound guy to get you a decent tone through the front of house (good luck!)
Cheers
David
David McCarroll
Find all posts by David McCarroll
09-20-2006, 11:02 PM
newbieguitarmaker
David McCarroll
Pre-amp wise, if money isn't really the deciding factor, you can't get much better than the Mesa
Boogie TriAxis
, which is an all-analog, all tube pre-amp but with the benefit of digital control over the storage and modification of presets - I've used a TA for about four years now, and they really do sound amazingly good - the G-Major , which I added about three months ago is probably the best $400 I have ever spent - other than intelligent pitch shifting, there is basically almost nothing this little gem won't do (the G-Major DOES do pitch shifting and harmonising, it won't however change majors and minors according to the scale you are playing, which apparently the G-Force will do).
power amp
Cheers
David
i have a yamaha preamp, but if i use my friend,woody, who is a sound guy i can trust him with my life lol
newbieguitarmaker
boogie triaxis
david mccarroll
marshall jmp
mesa boogie
mesa boogie triaxis
pitch shifting
power amp
rack pre
what effects is there in whispering a prayer
peavey bandit 112 effects loop problem?
what effects steve vai uses
pedal effects or rack effects?
how to hook up 2101 as effects only
For Sale Brand New M-Audio Black Box Reloaded
ibanezcollector
11:00 PM
Effects loop volume drop in Prosonic
sanchez
Gear and Equipment
09:06 PM
Single Effects Set up Run through Two Loops...Possible?
Gresh
Gear and Equipment
02:01 PM
fender twin reverb and effects loop?
SilverSurfer2
Gear and Equipment
01:49 AM
Rack Effects: what are the basics?
Frankie
Gear and Equipment
12:30 AM
11:24 AM
