Old 01-27-2007, 06:39 PM
alex10  is offline
Posts: 698  -  iTrader: (1)
Question
extension cabinet on a combo
i'm planing on buying a marshall 2x12 tube combo for practising a home,
but could i connect an extension cabinet to the combo for when i am gigging
if so how excatly do i go about this
regards alex,
Old 01-28-2007, 07:17 AM
bikeman  is offline
Posts: 660  -  iTrader: (5)
Re: extension cabinet on a combo
Yes you could. Buy a cab, hook it up to your combo - simple!
As long as your combo has dual outputs and the impedence of the cab matches the outputs....
Old 01-28-2007, 07:26 AM
Gudster  is offline
Posts: 441  -  iTrader: (0)
Most Marshall Cabs have a switch which allows you to select what ohms it uses.
Old 01-28-2007, 09:01 AM
bikeman  is offline
True, but not all. And not all have an 8ohm option if that's what you need. They're usually 4ohm or 16ohm.
extension cab, marshall cabs, tube combo
FS: Bogner Shiva Extension/Conversion Cabinet HIS ROYAL DARKNESS Classified Ads: Guitars and Gear 0 07-01-2006 05:06 PM
Info wanted on Legacy 212 extension cabinet TonyByers Gear and Equipment 8 01-04-2006 06:00 PM
Legacy head and cabinet... satchie Gear and Equipment 0 11-17-2005 04:17 PM
Extension cabinet for Tech21 Trademark 10, comments needed! Man1ac Gear and Equipment 0 06-28-2004 12:49 PM
