Old 07-10-2001, 08:39 PM
jem10  is offline
Posts: 76  -  iTrader: (1)
Funky Pickup Configurations and Selections
I have just finished rewiring my 7d with an X2N in the bridge, no single middle pickup and an Evo in the neck. I wired this with three way selector switch. Evo Neck / Both / X2N Bridge. I also wired in a push pull tone for parallel and single coil operation and a push pull vol for high bypass filter. I basically followed the satriani wire diagram as posted at ibanez.com but the high bypass isn’t working. Despite the latter the range of tones is incredible.
I was not expecting the X2N to be so beautiful clean!
Has anyone else tried alternative configs apart from the Breeds (7dbk) and the usual Evos (7v's etc)?
Old 07-11-2001, 03:29 PM
Patrick Deno  is offline
Posts: 478  -  iTrader: (0)
I dumped a Steve's Special in the bridge of my 7D. Does that count?
Chunkenstein delux! :biggrin:
LJ
pull tone
