Old 04-24-2003, 11:11 PM
triaxis  is offline
Posts: 118  -  iTrader: (0)
G major relay switching on a 3 ch Dual Rect? Help needed
Hi..
I'm in the market now for a G major after hearing all the good things abt it. What really caught my eye was the relay switching function.
However, my qns is, how do you connect the relay jacks to the 3 channel dual rect? I'm aware that there are 3 external outputs on the dual rect for each of its channel, one more for solo and another for effx loop. However, on the G major, I think there's only one output for relay switching? What type of relay jack is necessary? A Y splitter? A Stereo? or what can be done such that I can switch the 3 channels as and when I change presets via a midi footcontroller?
Any help is appreciated!
Thanks!
Old 04-24-2003, 11:29 PM
bduersch  is offline
Posts: 1,357  -  iTrader: (1)
The G-major has a stereo jack, so with a Y-cable, you can switch 2 items at a time.
I don't think that will do the trick for the Rec... I wanted to use the G-major to switch the channels on my Mark IV, and I could only switch 2 of the 3 channels.
I ended up buying a Rolls/RFX RP-93 to swtich channels on the Mark IV--it can switch 4 relays at a time. Combined with the G-major, I get major MIDI switching:
Rolls switch 1--R1 channel
Rolls switch 2--R2 channel
Rolls switch 3--LD channel
Rolls switch 4--graphic EQ
G-major switch 1--FX loop
G-major switch 2--reverb
Good luck!
--B
Old 04-25-2003, 12:05 AM
triaxis  is offline
Hey..thanks a lot for the information...I'll try to look for the Rolls/RFX RP-93 ..I think that should be sufficient for me...thanks!
Old 04-25-2003, 08:24 AM
bduersch  is offline
The RP93 is a heck of a deal--it's $150 new, generally $90-100 used. In addition to the 4 switches, it also has 4 loops, so you can use it to switch pedals in and out of your signal chain.
So aside from using it to switch the channels on my Mark IV, I also use it to switch my TS9-DX and CP-9 in and out of my signal chain.
--B
midi foot, midi footcontroller
