Thanks for the responses! I've already discovered that my DS-1 is a pretty quirky little pedal.. I initially had major problems with feedback, and couldn't figure it out.. Later on when I turned the whole thing on I didn't have any feedback at all. It turns out, it was interfering with my computer, which was on the first time. Must be all that crazy-fast stuff I have in my puter, right? :biggrin:
I'm using it as distortion on my clean channel (the distortion on my
Mesa Boogie Mark IV is great, but the DS-1 does a beautiful job of fattening up FRED pickups) and I do like my clean channels pretty bright.. For clean tones I usually prefer single coil pickups, so when I use humbuckers I end EQing to taste quite a bit.. Thanks for the suggestions, I'll try tweaking with the amp a little more.
Anybody here have a scanner and a Japanese DS-1? I'd be curious to see how the innards compare.. It wouldn't surprise me if the only difference is that some cheaper (and probably harder to find) transistors are used in the Japanese version.
