Gear and Equipment
Ground Control Pro Help needed
Gear and Equipment
10-07-2009, 01:42 PM
vy100
Posts: 410 - iTrader: (
Reviews: 3
I´ve bought a
Ground Control Pro
from a US dealer I´m waiting for. The
power supply
needed in the US is 110VAC-9VAC 500 mA 60Hz. I have a power supply 240VAC-9VAC 500 mA 50Hz. Is the Ground Control Pro ready to work at 50Hz?
Thanks
vy100
Find all posts by vy100
10-07-2009, 06:41 PM
LonePhantom
Posts: 5,365 - iTrader: (
Reviews: 98
Re: Ground Control Pro Help needed
I can't imagine you having any problems, but you would be best off actually contacting the company rather than asking here.
LonePhantom
Visit LonePhantom's homepage!
Find all posts by LonePhantom
10-07-2009, 07:50 PM
finstah
Posts: 595 - iTrader: (
Reviews: 3
I know mA if you are below the value you need than it's fine. But you are above in Hz. Not sure if that's a factor or not.
finstah
Visit finstah's homepage!
Find all posts by finstah
10-08-2009, 01:05 AM
LonePhantom
Reviews: 98
With mA if the power supply is above the value you need it's fine, not less.
eg. pedal needs 200mA, you have a 500mA you are fine
pedal needs 300mA, you have a 200mA not fine
LonePhantom
10-08-2009, 11:28 AM
finstah
Reviews: 3
LonePhantom
that's what I was trying to say. It was a LONG day haha
finstah
10-16-2009, 12:02 PM
vy100
Reviews: 3
finstah
Thats why I asked! I different Hz!
I asked
Voodoo lab
and the GCP works at 50 or 60Hz, no problem, so those who live in Europe don´t worry about that. The only issue is the tip of the power supply has to be wider that most pedals (i.e. boss pedals)
vy100
10-16-2009, 06:20 PM
LonePhantom
Reviews: 98
Do you have a chain based electronics store in Spain? If so they probably sell variable power AC adapters with a range of plug options. Find one of those and you should be right.
LonePhantom
11-13-2009, 06:47 PM
EL-CeeDee
Posts: 484 - iTrader: (
Just get the audio switcher too
( and find a proper midi cable with all connectors hooked up !! )
EL-CeeDee
Find all posts by EL-CeeDee
11-19-2009, 07:24 PM
ME.
Posts: 219 - iTrader: (
They do sell the original power supply at
www.thomann.de
Just so you know.
ME.
Visit ME.'s homepage!
Find all posts by ME.
ground control pro
midi controller
midi foot controller
power supply
voodoo lab
where do i solder the ground on a coil tap
room in control cavity for batteries?
is a string retainer needed for an ibanez headstock
ibanez rg3ex1 ground?
when is a refret needed
FS DMC GROUND CONTROL PRO
Rudy
09:47 PM
G major with ground control pro
aeromike
Gear and Equipment
09:18 PM
Gforce and Ground Control
Al M
Gear and Equipment
09:44 PM
Ground Control and Ground Control Pro
MidnightFlamed
Gear and Equipment
11:04 AM
Ground control PRO - check this out!
oooo
Gear and Equipment
12:40 PM
01:02 AM
