Old 01-03-2002, 01:27 AM
Project Guitar  is offline
Posts: 979  -  iTrader: (0)
Guitar DI Computer USB port
Is this the wave of the future?
Old 01-03-2002, 03:04 AM
Scoff X  is offline
Posts: 211  -  iTrader: (0)
it might be I would kill for it BUT it will probably be about 600 bucks :P
Old 01-03-2002, 08:46 AM
JESTER700  is offline
Posts: 2,234  -  iTrader: (0)
Nah. *Looks simpler than a POD, but lots could happen just in software. *Full function USB audio ports are &lt;$200, and a simple "imic" for macs are only $35, so I'd bet this'll run a couple hundred.
Old 01-03-2002, 11:21 PM
Two hands31  is offline
Posts: 4,989  -  iTrader: (0)
I would definitely buy something like that. *Especially if they made one for mics too.
Old 01-03-2002, 11:55 PM
Getthis  is offline
Posts: 267  -  iTrader: (0)
..........interesting..............
http://www.electrohill.co.uk/site1/a...C_F_X_772.html
(Edited by getthis at 11:12 pm on Jan. 3, 2002)
Old 01-15-2002, 11:38 AM
Getthis  is offline
specs?
Old 01-15-2002, 03:03 PM
Very cool that its powered from the USB port. *But remember that even though they hype the 24 bit convertors, you can't pump that high a stereo bitstream over USB. *It'll probably be 16 bit output.
Looks good, though...
Old 01-15-2002, 03:53 PM
Getthis  is offline
the specs for the Midiman/M-Audio USB Quattro soundcard running at certain audio resolutions:
2 inputs, 2 outputs: 24-Bit/96kHz
4 inputs, 2 outputs: 24-Bit/44.1kHz
2 inputs, 4 outputs: 24-Bit/44.1kHz
4 inputs, 4 outputs: 16-Bit/44.1kHz
4 inputs: 24-Bit/48kHz
4 outputs: 24-Bit/48kHz
so maybe the GuitarPort will support output of 24/96....... but the POD II has 20-bit and and POD Pro has 24-bit convertors and both sample at 31.250 Khz so.......... and maybe just the modeling audio will output through the GuitarPort and the backup tracks through your soundcard into the AUX in for the G.Port..... who knows, let's wait for NAMM....
(Edited by getthis at 3:07 pm on Jan. 15, 2002)
Old 01-15-2002, 05:59 PM
...color me stupid... ;-)
1) I was thinking "24/96" instead of "24 bit", which at 32k would have much lower bandwidth requirements.
2) Getthis is right - even 4 channels of 24/96 is possible over USB 1.1 (although just barely).
...now where DID I put that brain?...
Old 01-15-2002, 08:09 PM
Kremlin  is offline
Posts: 520  -  iTrader: (0)
Sweet! I've got a helluva computer, I wonder if that means I can run more effects at a time..
Old 01-16-2002, 04:29 AM
Kasper Kowalski  is offline
Posts: 118  -  iTrader: (0)
this sort of tech is definitely the way to go
the average home PC has way more grunt than your typical effects processor... imagine if you could get eventide harmonizers simply by installing the appropriate software........
Old 01-16-2002, 06:11 AM
keith  is offline
Posts: 363  -  iTrader: (0)
Call me stupid...but what is it supposed to do??? What's its use?
Old 01-16-2002, 08:48 AM
Kasper Kowalski on 3:29 am on Jan. 16, 2002
You can get many plugins for standard DX compatible audio editors. *TC electronics makes some great ones. *Never looked for harmonizers, but they gotta be out there - Antares AutoTune is...
pod pro
