Old 07-28-2007, 12:23 PM
ERDocJemfan  is offline
Posts: 39  -  iTrader: (3)
Guitar glass display case recommendations
Can anyone recommend a display case that I can purchase to display some of my collectible guitars? Would like to mount them on the wall in my studio similar to how the Hard rock does. Thanks
Old 07-28-2007, 02:49 PM
ScottB  is offline
Posts: 2,208  -  iTrader: (12)
Images: 8
Re: Guitar glass display case recommendations
A search at MF for "display case" yielded quite a few results.
Old 07-28-2007, 05:26 PM
yoyo1299  is offline
Posts: 637  -  iTrader: (0)
build one.
Old 07-29-2007, 12:33 AM
Active 80's  is offline
Posts: 98  -  iTrader: (0)
i would just buy those things you screw into the wall and hang ur guitar up and then take som 2x4s and build up a frame and put molding on it so its a little past the body of the guitar. then if you wanted you could put lighting on the cieling or use those cheapo little push lights on the inside edge of the frame.
im planning on doing this in my room. you wont actually be able to protect the guitar very well, but its very nice as a display that you can easily access the guitar.
oh and if you want you could put some like velvet looking stuff with padding behind it. if you do that you might as well just make a good size box, with the guitar holder thing built in... that might be cheaper than other things, but if your a handyman you could easily fit the box in a recess in the wall between the studs. that would be uber cool. i was planning on making a slit the thickness of the glass/plastic you would use on like the left side, so that you can slide it out so you can get the guitar out.
i think displaying them is cool, but i encourage playing them more.
Old 07-30-2007, 10:13 PM
jb4674  is offline
Posts: 4,010  -  iTrader: (0)
Reviews: 6
Check this company. I'm planning to order at least one of their cases for my chromeboy.
http://www.theguitararmory.com/tgahome.html
Jimmy
Old 10-28-2008, 09:16 PM
guitarart  is offline
Posts: 3  -  iTrader: (0)
TLSee Displays makes a wall-mount guitar display case
TLSeeDisplays com
and
TLSeeDisplays com / guitar-display-cases.aspx
help me....laquer problems projectjem Tech: Setup, Repairs and Mods 47 03-12-2009 01:49 AM
Somebody stole my guitar!! Please help me find it PatrickSimsCustomShopUSA Vendors, Auction & Reseller Talk 27 08-01-2006 01:04 AM
Transcript of Aussie Vai I'view (didnt know where to put it) TheOrangeChannel JEM and Universe Guitars 16 07-26-2006 12:52 AM
JEM's and UV's now in the molded case ;/// Rich JEM and Universe Guitars 57 02-23-2005 11:18 AM
Known history of Guitar.. (lots of people have it wrong) - a vwall Other 6-string Guitars (non-Ibanez brand) 10 05-09-2001 02:20 AM
