Old 09-23-2004, 12:53 AM
robinson  is offline
Posts: 3  -  iTrader: (0)
Guitar Neck Thickness
I think playing with a thin neck (not greater than 22 mm at fret 1) is easier (less force used) than playing with a thick one. Is it correct? Also, playing with a flat neck is is easier than playing with a round shap one. Am I right?
Thanks.
Old 09-23-2004, 05:55 AM
ukwan  is offline
Posts: 314  -  iTrader: (0)
depends on the player..
I find les Paul necks more comfortable than Ibanez necks.. just the fret access on a Les Paul isnt any cop unfortunatly but the tone makes up for it.
Old 09-24-2004, 11:50 AM
frethack  is offline
Posts: 115  -  iTrader: (0)
I personally like necks that are a little thinner (my UV neck is perfect), but my hands are a bit smaller. I have a feeling a lot of it has to do with hand size and comfortability. A friend used to get cramps REALLY bad from his Wizard neck, but he was just fine on the Les Paul and he had HUGE hands.
Just a thought.
Old 09-24-2004, 11:56 AM
power freak  is offline
Posts: 395  -  iTrader: (0)
I prefer thicker necks, wizrds hurt my wrists after a while. A wolfgang is about the size I would go for about 0.840" or so at the first fret. I also prefer a wider neck 1 and 3/4" nut preffered with a REALLY flat radius about 20", I also prefer a straight radius over a compound one. As for shape I like a really round C section the whole way down the neck.
Old 09-28-2004, 11:06 AM
jemaholic  is offline
Posts: 2,806  -  iTrader: (14)
Images: 13
I believe you can "learn" any style neck. Look at Vai with the Wizard neck, and gee-whiz, Yngwie might be even faster with a "C" neck on a Strat.
Certainly Eric Johnson is no slowpoke on a Strat, but wait- Dimebag smokes on his LTD and Randy Rhoads kicked EVERYONE's ass on a Les Paul Custom with a tree-trunk neck.
Rusty Cooley plays probably cleaner and faster than anyone I've heard on an 8 string neck which doubles as a canoe you can paddle across the river.
It's all about dedicating yourself to one particular style of guitar and then buckling down to some serious practicing.
eric johnson, fret access, ibanez neck, ibanez necks, les paul, les paul custom, randy rhoads, rusty cooley, thicker necks
