Old 01-25-2004, 05:27 PM
Ralph khoury  is offline
Posts: 451  -  iTrader: (0)
Harmonizer question
What is the cheapest/good quality polyphonic harmonizer on the market?
Old 01-25-2004, 06:51 PM
littlegreenman  is offline
Posts: 2,626  -  iTrader: (4)
Cheap and Good don't work together in harmonizers. The best way would be to buy a used Eventide, around $1000. I've bought every cheap harmonizer on the market up to buying an Eventide and discovered had I saved all that money I could have had an eventide from the start. Eventide is the only harmonizer I would even consider anymore. The TC electronics one is ok, but still not up to par and every bit as expensive.
Old 01-25-2004, 06:55 PM
I guess i will go for the Eventide eclipse! 2000us$
Old 01-25-2004, 09:29 PM
gkelm  is offline
Posts: 1,564  -  iTrader: (8)
The old Digitech IPS-33b would get you by for much less...not an an Eventide, but not a bad piece.
Greg
Old 01-26-2004, 12:43 AM
In all honesty, unless you want the latest greatest, or are going to use it for far more than guitar (like vox etc) the eclipse isn't even necessary, you can get a used H3000D/SX for $1000 or less and it has probably got all you need and more.
Old 01-26-2004, 09:50 AM
Thanks a lot for ur help!
eventide eclipse
