Gear and Equipment
HELP: Distortion pedal to work with my setup?
Gear and Equipment
02-27-2007, 11:57 AM
GuitarGod
Posts: 111 - iTrader: (
Hey guys,
I hear a lot of talk about which distortion/ overdrive pedals work best with what combinations, and although I've tried to relate those threads to my own setup, I fear I can't really make an informed decision so I figure I'd ask you guys to help me out since a lot of you have played pedals that I can't even find in stores here.
My set-up is as follows:
Guitars: Ibanez Jem7vwh (stock evo pickups)
Ibanez Reb Beach
RB10bk (pickups HS-3,HS-2,ToneZone)
Ibanez RG770DX (Evolution, IBZ USA, X2N)
Pedals: (not in an entirely decided order yet, still fooling around with order)
Planet Waves Chromatic Stage Tuner, Boss NS-2 noise supressor, Digitech Whammy reissue, Vox custom modded V847 true-bypass wah, Boss MT-2 Metal zone, MXR 10 Band Graphic EQ, MXR EVH Phase 90, Line 6 echo park.
Amp: Marshall JCM2000 TSL 100 (stock tubes) with 1960A slanted cab.
I just figured I would list all of the components. Now, my problem is with my
distortion pedal
. I play my marshall w a clean channel and I don't think my MT-2 is working for it anymore. I play mostly harder genres of metal, but also enjoy my Yngwie and Vai and Satriani-esque type players. So I would like something that can give me the low-end power to work with my amp but also enough clarity and smooth distortion, the best word to use is like a 'liquid' sort of sound. I would really appreciate any pedal suggestions or other comments. You guys are all very knowledgable so I'm bound to get something out of it.
Thanks,
Damian
GuitarGod
Find all posts by GuitarGod
02-27-2007, 12:10 PM
Rotti
Posts: 3,341 - iTrader: (
Re: HELP: Distortion pedal to work with my setup?
I dunno man, liquid smooth distortion with lots of gain and sustain is the hardest thing to find IMO. I went from an MT-2 to a Metal Muff. I like the Muff a lot. It's much "bigger" sounding than the MT-2. It is more transparent, it sounds good but it's not so smooth. I have also used a ts-9, bad monkey, guyatone od2, ds1, bd2, fat cat, blue doo, super tube, and a few others. Now I'm thinking I wont find smoothness from a pedal. I think it's more of an amp/speaker thing.
12:15 PM
Rotti
Visit Rotti's homepage!
Find all posts by Rotti
alex10
Posts: 698 - iTrader: (
how about a TS9,
and if you want more distortion use it alongside your amp on the crunch channel
alex10
Find all posts by alex10
02-27-2007, 04:16 PM
Racerx2k
Posts: 1,076 - iTrader: (
You MAY wanna try the Digitech Distortion Factory. It has plenty of tones, available. I sat down at GC one day, for over an hour or more, and tried lots of distortion pedals. The two that caught my eye (or in THIS case, EAR) was the
Marshall Guv
'nor Plus, and the Distortion Factory. at least with the Digitech, you get about 8 different types to choose from, where the Guv'nor is a one-trick pony.
Racerx2k
Find all posts by Racerx2k
02-27-2007, 07:45 PM
GuitarGod
Hey guys,
Thanks for all of your replies. I thought about the TS-9 at one point but the only thing that throws me off was in order to get a lot of gain out of it, I would have to use it through the Crunch channel of my amp or along with another distortion. It isn't a terrible thing but the only thing that throws me off would be switching from a high-gain tone to a
clean tone
in a suitable time frame. Maybe I'm just not quick enough with my feet
GuitarGod
02-27-2007, 07:55 PM
Gurj
Posts: 1,912 - iTrader: (
What about the
Scott Ian
DigiTech Black 13 pedal? They've got some clips over at the DigiTech site
http://www.digitech.com/products/Black13/main.htm
08:00 PM
Gurj
Find all posts by Gurj
02-27-2007, 08:02 PM
Racerx2k
GuitarGod
Hey guys,
Thanks for all of your replies. I thought about the TS-9 at one point but the only thing that throws me off was in order to get a lot of gain out of it, I would have to use it through the Crunch channel of my amp or along with another distortion. It isn't a terrible thing but the only thing that throws me off would be switching from a high-gain tone to a clean tone in a suitable time frame. Maybe I'm just not quick enough with my feet
The Distortion Factory has a TS-9 setting, which, by the way, has more gain available than the actual TS-9.
Racerx2k
02-27-2007, 08:04 PM
ivan
Posts: 403 - iTrader: (
and what about the Line 6
Uber Metal
http://line6.com/tonecore/uberMetal.html
http://www.line6.com/media/tonecore/...ER%20METAL.mov
ivan
Visit ivan's homepage!
Find all posts by ivan
02-27-2007, 08:18 PM
Gurj
ivan
and what about the Line 6 Uber Metal?
That was the other one I was trying to think of. I had a jam a while ago and I was pretty impressed with the crunch on it. Nearly brought one, but I prefer my amp's distortion.
Gurj
02-27-2007, 08:20 PM
alex10
GuitarGod
Hey guys,
well if you used two distortion pedals side by side and they were close enough together then you could step on both of them at the same time with one foot.
alex10
02-27-2007, 08:27 PM
waylay00
Posts: 3,763 - iTrader: (
ivan
No, no, no, no...This will not get you "smooth" distortion. I have one, but I only use it for practice at home. It's all right for a pure stand alone distortion pedal, but for layering, I would definitely not use it.
waylay00
Find all posts by waylay00
02-27-2007, 08:34 PM
ivan
I know what you mean Gurj, same happens to me but in my case I bought it
Waylay00, you're right. In fact this is why it's not my main distortion pedal but it could be an option. Let him try and decide.
08:40 PM
ivan
02-28-2007, 11:44 AM
GuitarGod
I did some research on the Uber Metal and I dont think it is for me. Thanks for the info on it. Has anyone played a Keeley Modded MT-2 in comparison to a stock one?
GuitarGod
02-28-2007, 08:40 PM
Cymbaline
Posts: 98 - iTrader: (
I use a Marshall Jackhammer pedal in front of the clean channel of my Carvin Valvemaster, and it's pretty crunchy. There's 2 settings, for either OD or Distortion, but I never use the distortion side, it's a bit muddy for me. The OD side has WAY more gain than a TS-9 so it's almost like a distortion itself. In fact, I sometimes use a TS-9 in front of it for solos.
The Jackhammer by itself is great for classic rock tones (AC/DC, Zeppelin, etc) and it's real deep and beefy sounding.
Cymbaline
Find all posts by Cymbaline
03-01-2007, 10:34 PM
mi2tom
Posts: 7,522 - iTrader: (
Ubermetal!
mi2tom
Visit mi2tom's homepage!
Find all posts by mi2tom
clean tone
custom modded
digitech whammy
distortion pedal
evh phase
evo pickups
ibanez jem
ibanez reb beach
keeley mod
marshall guv
mxr evh phase
overdrive pedal
planet waves
scott ian
uber metal
how to work out chords
how to setup ibanez zr tremelo
fret setup level how-to
what distortion pedal can take guitars string 10-60
What amp sounds good with the Jemini pedal?
Setup problem
al3x
Gear and Equipment
02:20 PM
Pedal Setup
al.
Gear and Equipment
01:45 PM
Good distortion pedal for dream theater?
professor_chaos
Gear and Equipment
12:40 AM
Best Metal distortion pedal
AARRGGHHH
Gear and Equipment
30
03-09-2003
01:06 AM
Expression Pedal? - which volume pedal will work?
mikek
Gear and Equipment
08:39 PM
01:02 PM
