Old 09-24-2007, 01:30 AM
Penguin  is offline
Posts: 78  -  iTrader: (0)
Help me set up my rig!
Hey guys,
I will be buying a Rocktron Xpression to use with my Mesa Mark IV. Which pedal should I get for switching channels and effects? I want to be able to switch from the lead channel with delay to the clean channel with chorus. How would I set this all up? I am fairly new to rack gear so any help would be appreciated!
Old 09-24-2007, 01:39 AM
reguv760  is offline
Posts: 1,197  -  iTrader: (23)
Images: 5
Reviews: 12
Re: Help me set up my rig!
the Xpression should be connected to the Mark's FX loop. Isn't there a FX loop bypass on that amp? use that feature to "bypass" whatever's in the loop with a 25 - 50% wet/dry mix. Changing the amp's channel will need a switching system (like a GCX). Since the Xpression doesn't have an external switching (like a G-Major), you might need a switching system along with a midi pedal to make it all work.
Actually, some midi pedals have external switching so you might have to do extra research on which ones have this feature.
Reg
mesa mark, midi pedal, rocktron xpression
