Gear and Equipment
help! my 350 ex trem sucks
Gear and Equipment
11-03-2006, 04:14 PM
DangerStorm
Posts: 74 - iTrader: (
I need to change the trem of a 350 ex to a better one.. any one have any ideas of a good one that will fit?
DangerStorm
Visit DangerStorm's homepage!
Find all posts by DangerStorm
11-03-2006, 07:38 PM
jemuniverse777
Posts: 307 - iTrader: (
Re: help! my 350 ex trem sucks
Get an
edge trem
and rout out the cavity. Ive done it to a couple guitars and its very easy to do. The only thing is you will lose some visible material that will make the cosmetics of the guitar look choppy. If you need pics to see what I mean, just PM me. I dont have time to take them now.
jemuniverse777
Find all posts by jemuniverse777
11-03-2006, 07:43 PM
DangerStorm
How much material has to come off? I would do it if I could use my dremel
DangerStorm
11-04-2006, 06:07 AM
LonePhantom
Posts: 5,368 - iTrader: (
Reviews: 98
I've used a dremmel and some sand paper to fix a cavity for retro-fitting an Edge trem. You may not get the neatest job done but it does it. I'd just get a Gotoh Licenced
Floyd Rose
for the job though. Should be a direct fit.
LonePhantom
Visit LonePhantom's homepage!
Find all posts by LonePhantom
11-04-2006, 02:26 PM
Iplaythegeetar
Posts: 9 - iTrader: (
I believe an OFR should work in the cavity of the 350.
Iplaythegeetar
Find all posts by Iplaythegeetar
11-05-2006, 12:31 PM
MetalZone
Posts: 273 - iTrader: (
an OFR and Gotoh should be a direct fit. I'd suggest a Gotoh coz it's cheaper and equally as good if not better than an OFR.
MetalZone
Visit MetalZone's homepage!
Find all posts by MetalZone
11-05-2006, 12:50 PM
DangerStorm
They don't make those with pop in
trem arms
do they? Sure would be nice if they did.
DangerStorm
11-05-2006, 10:04 PM
mi2tom
Posts: 7,522 - iTrader: (
Is yours fitted with an edge3, I haven't had any problem with it, maybe some setup problem
mi2tom
Visit mi2tom's homepage!
Find all posts by mi2tom
11-05-2006, 10:38 PM
DangerStorm
yeah a
Edge III bridge
but when I try to dso some whammy work the freakin bar comes out of the socket ....it's like it's not long enough. I don't have that problem on my 1550... I changed the pickups in it so it sounds and plays good so I am happy with it except for that.
DangerStorm
11-05-2006, 10:50 PM
chef21
Posts: 668 - iTrader: (
there is a screw in the underside you can tighten to keep the bar from pulling out. An OFR does directly swap in witout any mods as will a gotoh floyd, i did it to mine. chef21
chef21
Find all posts by chef21
edge iii bridge
edge trem
floyd rose
trem arm
trem arms
what trem is on the rusty cooley
how to tighten zr trem
how to set up a strat trem
How to block ibanez trem
is my edge trem bar in all the way
Replacement of your trem arm - "tutorial" with pictures
Jammy
Tech: Setup, Repairs and Mods
93
05-16-2009
06:56 AM
Trem angle
wangbar
06:37 PM
UV Trem plate changeout - Encountered a glitch.
bob oakman
05:15 PM
cure for a crappy trem? - my beloved rg-450 sucks now
jem7vwh
07:33 PM
Repairing trem knife edges - Trem on my JS1000 will not retu
Jason Stone
Archived Topics and Common Questions - GO HERE FIRST
09:24 PM
11:59 AM
