Old 08-15-2006, 06:27 PM
chilln2music  is offline
Posts: 264  -  iTrader: (1)
Help with Edge Pro whammy bar!
I want my whammy bar to fall down towards the volume pot when I let go of it (don't want to push it down). I can accomplish this by taking off one of the white bushings, however when I do that the arm has some play in and is not smooth and "tight" feeling.
Is there anything I can do to get the results I am looking for?
Old 08-15-2006, 07:19 PM
Silverburst  is offline
Posts: 488  -  iTrader: (1)
Re: Help with Edge Pro whammy bar!
It'll happen as soon as they wear a little. When I replace old with new bushings, I must say the tightness disappears prety quickly (after a few months). maybe you could sand boths bushings a little, or don't you have a guitar shop in the neighborhood that would want to trade yours with used ones ?
Old 08-17-2006, 02:35 AM
I just recently started using the whammy bar again. Once the bushings "wear down" does the arm get some play in it or is it just the bar swings more freely?
Old 08-17-2006, 05:11 AM
it swings more freely. never had the issue of a "loose" whammy bar that had more play. I can imagine if your bushings are really extremely weared out, but it never happened to me because I don't like bars that swing up and down like a clock
guitar shop
Edge mysteries solved!!......? - Answers to some common ques Jason Stone Tech: Setup, Repairs and Mods 18 05-27-2008 09:35 AM
WTT Black Edge whammy bar for a Black Lo TRS whammy bar RG_76 Classified Ads: Guitars and Gear 5 07-11-2006 07:03 PM
WANTED: Edge or Edge Lo-Pro Tremolo Whammy Bar sfx70 Classified Ads: Guitars and Gear 2 01-19-2006 02:07 PM
edge pro whammy bar analogcreature Gear and Equipment 7 04-04-2005 06:59 PM
Tightening Whammy bar on Edge Tremlo - Can I tighten the bar warthog Tech: Setup, Repairs and Mods 6 05-01-2001 11:09 PM
