Old 10-24-2007, 06:16 PM
B@SZ  is offline
Posts: 10  -  iTrader: (0)
Question
Help with my rig...
Hi Everybody!!!
I hope somebody can help me, I got these stuff but I dont know what kind of output do I need, I heard that to run the Mesa Pre Rec live I need a Power Amp...
Furman Power Conditioner
TC G-Force
Mesa Boogie Rectifier Recording Pre
I want to do some live gigs, but what kind of Output suits me better? Do I need a Power Amp for the Rec Pre? what is best?
Old 10-24-2007, 07:45 PM
reguv760  is offline
Posts: 1,197  -  iTrader: (23)
Images: 5
Reviews: 12
Re: Help with my rig...
you definitely need a power amp and a matching cab to go with that setup. To get the full-on Recto tone with that Pre, you might as well get a 2:100. However, you can find other tube power amps of the same or lesser wattage to give ya a Recto tone with a punch that would only be defined by which power amp is used.
Not sure what your budget is but ya can check into the older Mesa power amps [2:95, 3:95] or a 2:90 as they have the Simul-class system that makes the guitar sound "3D". If 90W is a little bit too much, ya can look at a Mesa 50/50 [or 2:50]. If Mesa isn't up your alley, ya can check up VHT poweramps.
As for the rest of the gear, you'll need a midi pedal for the G-Force and a midi switching system [like a GCX] to control the amp and whatever patches you have on there
Reg
Old 10-25-2007, 09:25 PM
finstah  is offline
Posts: 595  -  iTrader: (2)
Images: 4
Reviews: 3
I've got a VHT 2/50/2 and it blew away my old JCM800. Great amp. If you want more low end go for the 2/90/2.
You won't be disappointed in VHT. Amps or cabs.
BTW, also had a G-Force. Great effects and killer pitch tracking. The secrets are in the Mods and Matrix.
Old 12-08-2007, 01:34 PM
albee1952  is offline
Posts: 784  -  iTrader: (2)
If you can find one, a used MosValve power amp is a great sounding bargain (80 watts per channel) for a rack-based guitar rig. The VHT is great but will cost you.
Old 12-10-2007, 01:26 PM
rty13ibz98  is offline
got one of those old mosvalve amps. great sounding guitar amp. not super clean, but guitar based power amp.
rich
Old 12-13-2007, 01:26 PM
7 Dying Trees  is offline
Posts: 1,708  -  iTrader: (4)
You'll need a power amp and a cab. I'd actually recommend keeping an eye out for the VHT stuff, or actually a rivera TBR-3 or TBR-5, as they are both awesome power amps that noone seems to want, and can be had cheap, and it's rivera, so it's built extremely well.
furman power conditioner, mesa boogie, mesa boogie rectifier, mesa power amp, midi pedal, power amp, power amps, rivera tbr, sounding guitar, tube power amp, valve amps
