Old 10-23-2002, 11:18 PM
Metalgoth  is offline
Posts: 40  -  iTrader: (8)
How do I ID my Dimarzio pickup?
I recently bought a very old RG560, and saw that the bridge humbucker didn't match the two singles. I popped it out, it looks just like the Evos I used to have, it says only Dimarzio and Made in the USA on the back. I checked their site, and most of their hums are visually identical. Is there any way to find out what pickup it is?
Old 10-23-2002, 11:29 PM
kennydoe  is offline
Posts: 3,416  -  iTrader: (1)
There should be a "DP" number on there someplace...maybe a stamp on the back?
If you can find it, cross reference is at www.dimarzio.com.
If you can't find it, call them/email them and tell them about it - they're very helpful, knowledgable people over there.
good luck
~Kenny
Old 10-23-2002, 11:45 PM
dcord  is offline
Posts: 1,077  -  iTrader: (8)
Most of the unmarked DiMarzio's I've seen turned out to be Super Distortions or PAFPros. It's easy to distinguish between the two by the size of their polepieces.
Old 10-24-2002, 07:41 AM
Two hands31  is offline
Posts: 4,989  -  iTrader: (0)
There's basically two ways.
The number stamped on the bottom (should be a DP-### (3 digit number) and maybe an "F" at the bottom if F-spaced).
If no number, then just look through the site and compare it with pics.
Old 10-24-2002, 12:40 PM
I checked it out some more, and there is no number at all on the back, stamped or otherwise. I hadn't thought to check, but it is definitely not f-spaced. As I mentioned above, so many of the pickups on Dimarzio.com are visually identical. I supppose it probably is a Super Distort or PAFPro. I'll probably replace it with something else, but without ID it's got no resale. The guitar was a great deal regardless.
Old 10-24-2002, 02:08 PM
jono  is offline
Posts: 5,004  -  iTrader: (2)
I'm no tech expert but if you can get to measure the DC resistance of the pickup you might be able to match it up to the figures on the DiMarzio website?
Old 10-30-2002, 03:06 PM
Drew  is offline
Posts: 4,538  -  iTrader: (4)
Not even a patent #? That's how i was able to distinquish the paf from the air norton that my shop was supposed to (and forgot to) swap between the 7620 and 2027 when they were changing the bridge pickups... lol. Thankfully, the paf compliments the Evo a lot better than i thought it would, so...
-Drew
Old 10-30-2002, 04:34 PM
sniperfrommars1  is offline
Posts: 3,302  -  iTrader: (0)
I still think the paf pro is the ultimate match for the evo. Just my two cents though
Old 10-30-2002, 08:25 PM
Drew  is offline
lol, swing by the thread i just started over in the 7-string forum. turns out it's a frickin' TZ. how the HELL did that get into the neck position??
anyway, they don't make a paf pro 7 YET... although i hear joe has the first, so...
-Drew
Old 10-31-2002, 01:37 AM
Could it also be an air zone pickup? arent those neck position pickups as well
Old 10-31-2002, 02:35 AM
RSVampire  is offline
Posts: 1,813  -  iTrader: (6)
they make paf pro 7's and korn was I believe the first to have the first paf pro 7's not joe. joe has the first Fred 7. and those aren't available
Old 10-31-2002, 03:56 AM
Drew  is offline
I'm just going what someone quoted off here as coming off dimarzio's websitem re: the paf pro thing. and i'm pretty sure Korn uses paf (NOT paf pro) pickups- that's what's spec'd in the k-7 model, anyway...
Can't be an Air Zone pickup- it's a 7-string pickup, remember?
-Drew
Old 10-31-2002, 07:29 AM
Yes, K7 has the PAF7 (not PAF Pro).
Old 10-31-2002, 02:14 PM
vai had paf pro 7's made at one time didnt he? In like his prototype universes? He was still using paf pros in his jems then so it only makes sense??? who knows
air norton, bridge hum, bridge humbucker, bridge pickup, bridge pickups, neck position, paf pro, paf pros, string pickup, super distortion
