Gear and Equipment
how do you make a fenders dis sound better
Gear and Equipment
08-02-2005, 12:34 AM
metalguitarist7778
Posts: 493 - iTrader: (
I have a fenderhot rod delux and the dis is horible any suggestions instead of getting a pedal? (Oh and i cant turn the volume to high so f that idea).
metalguitarist7778
Find all posts by metalguitarist7778
08-02-2005, 01:11 AM
j.arledge
Posts: 1,804 - iTrader: (
30
Re: how do you make a fenders dis sound better
well, a boss ds-1 with an overdriver(zw44) . That combo can make a really nice distortion set up.
maybe just an overdriver will do the trick. How old are the tubes in it? may play around with new 12ax7s to see if you can't get something more that you like, if you do get some 12ax7s electro-harmonix or jj are both pertty soild brands.
j.arledge
Find all posts by j.arledge
08-02-2005, 01:29 AM
Gex
Posts: 962 - iTrader: (
The Hot Rod Deluxe just isnt a metal amp, its a clean/low gain amp.
If you need a metal sound, your best bet is getting a metal amp. Sure, you can try some pedals, but they are not going to sound as good as an amp's distoriton.
Gex
Find all posts by Gex
08-02-2005, 03:44 AM
guitarshredder7
Posts: 610 - iTrader: (
yeah get a tube half stack or combo from carvin.com
guitarshredder7
Find all posts by guitarshredder7
08-02-2005, 02:53 PM
metalguitarist7778
from carvin ay wellm im not sure this amp is pritty good and i vcould just get a pedal and a thing that letsa you not have to get new batteries for it.
metalguitarist7778
08-02-2005, 08:59 PM
JM5150
Posts: 527 - iTrader: (
Make it better by buying a Marshall
JM5150
Find all posts by JM5150
08-02-2005, 09:38 PM
j.arledge
30
i'd play the marshall before ever getting one. Evrey marshall i have played i didn't like much at all,simple put i hate marshall and feel that they are totally over rated P.o.s. amps .
Saying this i will say that sound is extermly subjective and it is very hard to offer good advice because someone can't just say "you'll love the way this sounds or this pedal is the one for you" it . So in short screw everbody else because they aren't you and dont like the same things as you, play all the stuff you want first hand, it maybe hard but it you are much better off knowing exactly what you need .
i played a digitech
death metal
today, it gave some alright distortion but it was a bit noise, and out of curiosity i plugged it into a
marshall avt
50 combo and it was ok until i turned the pedal off.
j.arledge
08-02-2005, 09:43 PM
Jemwielder
Posts: 1,000 - iTrader: (
Reviews: 6
yeah i'm not big on marshall either. I actually like fender amps, but then again i'm more of a fusion/rock guy than full blown metal. Either get yourself a good pedal and a dc unit so you can plug it in the wall or get a new amp.
Jemwielder
Find all posts by Jemwielder
08-02-2005, 10:10 PM
Drew
Posts: 4,538 - iTrader: (
I owned a Hot Rod Deluxe for a while - great amp, awesome cleans and great bluesy overdrive. But, it's not a "metal" distortion amp, and there's nothing you can do to it to change it. If you want a more metal distortion, you realyl should be looking elsewhere...
-D
Drew
Visit Drew's homepage!
Find all posts by Drew
08-02-2005, 11:52 PM
sanchez
Posts: 120 - iTrader: (
If you like Fender amps then have a look for a Prosonic head or Combo.
If you want to keep what you have, (The hot rod delux is a great amp by it's own right) you really need to put one of the many OD pedals in front.
Sanchez
sanchez
Find all posts by sanchez
08-03-2005, 08:05 AM
Solo Hero
Posts: 135 - iTrader: (
try some overdrive pedals with it, if that still doesn't work, then get a new amp that produces the distortion you like
Solo Hero
Find all posts by Solo Hero
08-03-2005, 12:08 PM
ElectriK
Posts: 150 - iTrader: (
JM5150
t.t Marshalls are overpriced and not even that good.
ElectriK
Find all posts by ElectriK
08-03-2005, 08:10 PM
Gex
ElectriK
The new ones are, the JCM 2000's, AVT's and MGs.
But get an OLD original JCM 800 or JMP or plexi, crank it up, put a pedal in front, and they're great.
Gex
08-14-2005, 01:04 AM
metalguitarist7778
it doesnt matter i just got a vox ad100vt its pritty good
metalguitarist7778
death metal
marshall avt
overdrive pedal
how does korn get their sound
how to make an evh 5150 replica guitar
How to make brown sound
"how to make" " gloss enamel"
how do them make the swirl jem guitr
Your sound
Allen Garrow
Dave Weiner Official Forum Archive (SEE NEW LOCATION)
06:58 AM
Mesa Nomad 45 2x12: thoughts and sound clip
Drew
Gear and Equipment
05:29 PM
how do you get vai's sweet sound??
tonluvara
Gear and Equipment
164
04-04-2004
12:25 PM
A simple question concerning the sound of RG3120
particlestorm
04:48 AM
01:41 PM
