Hey, no problem
@nato: It has two modes, normal phaser and jet-off. The phaser itself sounds very decent, but I miss a little more presence. On top of that it introduces a small amount of noise to the signal which is noticeable when playing alone.
It runs on two 9v batteries, so it has quite a bit of headroom and does not seem to distort under the conditions in which I use it - I can maybe push it more with a louder signal to increase the signal:noise ratio, but I didn't try that.
The speed does not go insanely fast, but still over a few Hz.
The jet mode is very... uhm... artisic. It basically adds a jet-like noise to the signal if you play it hard enough. The loudness and tone of that jet is controlled with the two knobs on the right. Maybe it is good for shoegazer?
