Gear and Equipment
instrument vs. speaker cable
Gear and Equipment
04-03-2005, 02:14 PM
Two hands31
Posts: 4,989 - iTrader: (
I know there's a reason there's a difference, and I know that speaker cables are shielded more, but is there any harm that can be done by using an instrument cable to connect a head to a cabinet rather than a speaker cable? Or is it just a sound quality thing?
Two hands31
Visit Two hands31's homepage!
Find all posts by Two hands31
04-03-2005, 03:58 PM
Drew
Posts: 4,538 - iTrader: (
Re: instrument vs. speaker cable
I think it has a lot to do with impedance, and as such, using an instrument cable is a GREAT way to fry your output transformer.
I accidently used a speaker cable one time as a lead between my guitar and a Mark-IV I was testing - sounded like absolute crap, I thought the amp had a grounding problem until I tried a different (i.e - instrument) cable.
-D
Drew
Visit Drew's homepage!
Find all posts by Drew
04-03-2005, 04:55 PM
red5
Posts: 2,639 - iTrader: (
Yes, speaker cables are not only generally shielded more, but they are much fatter wires too. Using thin instrument cables will result in loss of tone and possible damage to the amp (it's just like setting the wrong impedance, not all the signal gets through, comes back to the amp and kaboom!)
red5
Find all posts by red5
04-03-2005, 04:58 PM
red5
Drew
-D
You are lucky you didn't fry your transformer or some tubes on that thing. At least it wasn't yours though
red5
04-03-2005, 05:10 PM
rgr
Posts: 1,791 - iTrader: (
To set the record straight, instrument cables are shielded (coax), speaker cables are not (2 wires in parallel). That's why it sounded like crap when you used a speaker cable as an instrument cable. It won't hurt anything but your sound to use a speaker cable as an instrument cable, but as Drew can attest, you don't want to do it. But, instrument cables are not made to handle the current that speaker cables are, so you could fry the cable and possibly your amp if you use an instrument cable for speakers. "Probably" won't hurt anything at low volumes but at high volumes when you are pushing some juice, the potential for damage is there, so it's not recommended.
Roger
rgr
Find all posts by rgr
04-04-2005, 01:07 AM
Two hands31
Cool, thanks guys. I picked up some speaker cables for my new amp long before I started this thread, but my bassist is using a regular instrument cable between his amp (Yorkville XM250 I think, it's a 1x15) and his extension cabinet (Yorkville XM210 or something, it's a 2x10 with a tweeter). It sounds fine, but I was pretty sure there was a reason you shouldn't be doing it
Two hands31
04-04-2005, 02:19 AM
127.0.0.1
Posts: 34 - iTrader: (
Here's a good article about guitar cables, speaker or instrument.
http://www.guitarnuts.com/technical/cords/index.php
127.0.0.1
Find all posts by 127.0.0.1
04-04-2005, 05:08 AM
tobe
Posts: 260 - iTrader: (
Its true, do not use instrument cables for power outputs on amps....as stated above speaker cables are not shielded and have less resistance to the electricity flowing through 'em. Using an instrument cable to connect a
power amp
to a speaker puts a higher load on the amp, and can really mess it up...If your bass player is using a
solid state amp
it could totally fry it in the long run....good luck, T
tobe
Visit tobe's homepage!
Find all posts by tobe
04-04-2005, 01:47 PM
Drew
red5
No, it was the other way around, I was running a speaker cable between my guitar and the amp's input. Lots of noise and static. No danger of blowing anything.
Now, why GC had a 20-foot speaker cable sitting on top of a guitar amp is beyond me...
-D
Drew
04-04-2005, 07:34 PM
red5
Drew
-D
Oh alright, your IQ just gained a few points lol ;-)
red5
04-04-2005, 07:45 PM
Uthark
Posts: 150 - iTrader: (
Maybe somebody had disconnected a
rack system
or half-stack and decided to leave the cable there...
Uthark
Find all posts by Uthark
04-04-2005, 08:10 PM
kennydoe
Posts: 3,416 - iTrader: (
My tech once said "you can tell me you're using an instrument cable in place of a speaker cable...you can also tell me you get 10,000 miles between oil changes. I won't be impressed either way."
kennydoe
Visit kennydoe's homepage!
Find all posts by kennydoe
extension cab
power amp
rack system
solid state amp
speaker cab
how to build a speaker cabinet
if my clip is on too long what happens to my speaker
how to parallel speaker cabinets
what is the best way to ship a musical instrument?
18ga for speaker cab?
A guide to choosing tubes and cabinets!
power freak
Gear and Equipment
78
09-18-2011
11:35 PM
Have some Evidence Audio Cable info for you guys
Paul Secondino
Gear and Equipment
05:46 AM
guitar cable wiring trouble
nocebo
Gear and Equipment
08:14 PM
Building my own instrument cable? - Made my own
Triangle
Gear and Equipment
12:13 AM
01:43 PM
