Never worried about that, but maybe somebody could tell me. I use at home a JCM 800 50w 2 x 12 with a korg A3. This amp has only a channel and two inputs (lo and high sensitivity). As i use it at home itīs always in the low sens input, and sounds good with the FX, but when through the high input its pure ****, even turning down the preamp volume (has a pream and a master vol). Is it just the FX setting?Anything wrong with this input?Maybe should i try connect the FX through the direct input?
Apart from this question, what do you think about this amp (JCM)
A friend has just bought a Hughes and Kettner Zentera. Donīt know what to say, neve liked
solid state amps. Sounds good but seems something is missing when to its sound. Whatīs your oppinion about this one?
Thanx.
(Edited by urkoman at 2:50 am on Mar. 27, 2002)
