Gear and Equipment
JSX Class
Gear and Equipment
04-26-2005, 02:22 PM
Praetorian
Posts: 422 - iTrader: (
JSX Class
Hey guys, I was wondering, what class amp is the JSX? I keep hearing most guitar amps are class A/B which doesn't make sense to me becuse Class A/B only gives a partial replica of the input signal wheras class A is the whole signal. I know there are some class A amps out there, though most of them are boutique amps, but then what about the most popular ones? Such as, are all the Marshalls class A/B? I know Mesas are almost all A/B besides the Lone Star special, and then what about Fenders? And the Legacy and JSX? I've just spent about a month learning about amplifiers in my Apprenticeship class but it wasn't focused on musical applications and they don't use tubes anymore. Anybody have a clue?
Praetorian
Visit Praetorian's homepage!
Find all posts by Praetorian
04-26-2005, 03:15 PM
jt93
Posts: 20 - iTrader: (
Re: JSX Class
Praetorian
im about 99% sure it's an a/b amp. most class a's i have seen (not a lot by any means) are low output (30-50w), and expensive (2-3k). a high wattage pure a would be (i would think) very expensive. i did a google for 'class a guitar amp' and found
http://www.classahighperformance.com/
lots of expensive stuff there
jt93
Visit jt93's homepage!
Find all posts by jt93
04-26-2005, 03:29 PM
rgr
Posts: 1,791 - iTrader: (
Re: JSX Class
Definitely A/B, even a 50W class A amp would require quite a few output tubes and generate alot of heat.
Roger
rgr
Find all posts by rgr
04-26-2005, 03:44 PM
red5
Posts: 2,639 - iTrader: (
Re: JSX Class
I can guarantee you it is not a Class A. Most likely A/B but it could be B as well.
Vox AC15 and AC30s are Class A, as well as most Bad Cats, Laneys and Soldano makes a Class A. There are a couple I am forgetting too. I found a company that makes handwired class A amps that run at 5 watts on just a single power tube!
red5
Find all posts by red5
04-26-2005, 06:47 PM
Praetorian
Re: JSX Class
yeah, thanks guys. I'm looking into AC30's now. I don't know, why is it that most guitar amps are A/B when it doesn't give the full output signal? It's like cutting a quarter off your pickups. I guess it must be OK because from what I hear the JSX is a wondeful amp, but I guess this is the reason everyone loves the SLO100. A high gain 100 watt Class A amp, it's a beautiful thing!
Praetorian
04-27-2005, 12:25 PM
Drew
Posts: 4,538 - iTrader: (
Re: JSX Class
Praetorian
...but I guess this is the reason everyone loves the SLO100. A high gain 100 watt Class A amp, it's a beautiful thing!
The SLO's A/B too.
There's a LOT of debate on this, naturally, but A/B is actually fairly well suited for guitar - it'll give a bit of extra definition in relation to a true A. B is generally held to overdrive too abruptly (all or nothing) for a guitar amp, but A/B is totally workable.
Also, apparently most "Class A" guitar amps aren't actually true class A. I don't understand the exact differences, but do a Jemsite search and a few links to some interesting articles should turn up.
Basically, finding a transformer that can handle more than 50 or so watts in Class A is prohibitive.
-D
Drew
Visit Drew's homepage!
Find all posts by Drew
04-27-2005, 12:50 PM
old_metal_head
Posts: 144 - iTrader: (
Class A Class
http://www.mesaboogie.com/US/Smith/ClassA.htm
old_metal_head
Find all posts by old_metal_head
04-27-2005, 01:30 PM
rgr
Re: JSX Class
SLO's are definitely A/B, as well as most Laneys. I think they make an AC30 type amp that may be "class A" although, as Drew said, "true class A" in guitar amps is debateable. As far as class A being more efficient that A/B, it's quite the other way around, A is considerably less efficient, hence why you don't see class A amps over 30 or so watts.
The reader's digest version of the way class A works is that the
power amp
is biased so the zero line of the sine wave is right in the middle of the tube(s)'s amplification range and as the wave swings positive or negative, the same tube(s) amplify the signal both ways, so the tube is always "on" even when there is no signal. The creates a nice "vintage" tone, warm and smooth, and usually "spongy". Class A/B amps use at least 2 (or some other even number) power tubes and are biased (you'll see why biasing is so important now) so that the zero line is "between" the tubes (or pairs, triplets, etc..., you need an equal number of opposing tubes). When a signal is applied, one set (or side) of power tubes amplifies the positive side, then when the sine wave crosses the zero line, that set turns "off" and the other set of tubes amplifies the negative side. Class A/B amps are usually louder, cleaner, and tighter than A amps.
So you can see, class A/B can use the full power of a tube for each side of the wave, while class A can only use half (or less) of a tube's power for each side of a wave. Also, since tubes in class A are always "on", they generate more heat that class A/B amps.
Please note, before I get hammered, this is quite a simplification and doesn't try to explain all the nuances, or possibly be 100% correctly stated, but is supplied more to help as a visualization of how the different types of
power amps
work.
Roger
02:47 PM
rgr
04-27-2005, 01:38 PM
Drew
Re: JSX Class
"Reader's Digest version" - awesome!
And that's a very clear explanation that corresponds pretty well to my vague udnerstanding of the subject, so props for that too.
Myself, I tend to like a very spongy response for lead playing - this is part of the reason I like lower wattage (even A/B) amps. I'd probably love a low-wattage two- or three-channel high gain class A head if someone would just build one, but for now my "simul-class" (whatever that means) 45-watt Nomad is working out pretty well...
Drew
04-27-2005, 02:39 PM
vaijem777
Posts: 2,980 - iTrader: (
Re: JSX Class
I tend to like my older Matchless Chieftain for cleans, but have really fallen in love with the lead sounds I'm getting from my
Bogner Shiva
. Definitely the nicest all-around A/B amp I've played through.
There is definitely a lot to be said for a nice, low-wattage single-channel Class A amp though. The nuances and personality of that type of amp can be a lot of fun to play with
vaijem777
Visit vaijem777's homepage!
Find all posts by vaijem777
04-27-2005, 02:47 PM
Drew
Re: JSX Class
vaijem777
I tend to like my older Matchless Chieftain for cleans, but have really fallen in love with the lead sounds I'm getting from my Bogner Shiva. Definitely the nicest all-around A/B amp I've played through.
Why is it, whenever you post, I have near-unbearable attacks of G.A.S? Man... It's probably a good thing I've never gotten a chance to play a Shiva, because I'd probably fall for it pretty hard.
Drew
04-27-2005, 02:51 PM
vaijem777
Re: JSX Class
Drew
LOL I've pruned my gear collection a LOT, but kept most of the good stuff
The Shiva is the closest I've come to the "perfect" amp. I'd definitely take the EL34 version over the 6L6 though. MUCH more "organic" sounding. It just seems to breathe more (definitely has the nice, warm
Jerry Cantrell
tone!)
Plus, it's been road-tested and pulled through like a champ (even after being dropped and getting knocked over a couple of times) The thing is built like a rock!
vaijem777
04-27-2005, 06:48 PM
red5
Re: JSX Class
Drew
The SLO's A/B too.
I say Soldano makes A Class A amp, and people assume it's the SLO... that says a lot!
red5
04-27-2005, 06:53 PM
red5
Re: JSX Class
Praetorian
You are completely not understanding Class A. Class A does not necessarily/always/ever sound better than Class A/B or B, it's just different. It's not like taking a class A/B amp and running your tubes hot or boosting your input more for more power tube OD. Usually it's pretty warm and have lots of highs.
And I must add most Class A amps are cathode based which means they are auto biasing.
Listen to rgr and be forwarned that Class A amps eat tubes in a way that puts the Marshall Major to shame (ie really fast!).
06:59 PM
red5
04-28-2005, 12:34 AM
rgr
Re: JSX Class
If Soldano makes a Class A amp, it would be the Astro head or the AstroVerb combo. Both are small 20W amps but their website doesn't say if they are class A or not (at least that I saw on a quick look). It is possible to make low wattage A/B amps too, a pair of EL84s or 6V6s will put out 20 - 30W in A/B. Red5, it was Drew that thought the SLO was class A, so those comments weren't directed at you. I did have a HR50+ head, probably the best sounding amp I've owned, never had the $ for a SLO, I would only assume that they are awesome!
Roger
rgr
bogner shiva
jerry cantrell
jsx combo
power amp
power amps
what is the difference between studio and class les paul
diezel vh4 amp class a?
vht class a?
an i carry a guitar on a first class flight?
what is the difference between a class a amp and a
BC Rich USA class axe Bich
analogcreature
03:25 AM
Class A, Class A/B and Solid state
sanchez
Gear and Equipment
06:40 PM
Fender amps - class A or B?
jpi
Gear and Equipment
07:58 PM
04:46 PM
