Old 02-20-2009, 07:36 PM
PrinceAlice  is offline
Posts: 69  -  iTrader: (0)
Reviews: 6
Keri Kelli Volume Pedal Trick????
A few months ago Keri Kelli the lead guitarist for Alice Cooper, had a volume pedal set-up to go from clean to distorted on his amp....Where, it's clean when it's open and distorted when he punches it down. Does anyone have a clue how to do that???
P.S. He says he uses an ernie ball VP JR. if that helps!
Old 02-20-2009, 10:21 PM
speedy mcfeely  is offline
Posts: 293  -  iTrader: (1)
Re: Keri Kelli Volume Pedal Trick????
2 amps, stereo pedal.
Old 02-21-2009, 12:33 AM
ColinMmmmm  is offline
Posts: 1,068  -  iTrader: (1)
You could probably get any volume pedal and skip one of the teeth inside, then when you put it in the down position it isn't really off, and likely pretty clean.
Old 02-21-2009, 02:39 AM
teokiatuan  is offline
Posts: 425  -  iTrader: (0)
http://www.youtube.com/watch?v=2jZFu...e=channel_page
Old 02-21-2009, 09:38 AM
The Euphor  is offline
Posts: 2,948  -  iTrader: (4)
Check out Steve Morse's setup. He uses volume pedals to control every effect.
Old 04-08-2009, 03:28 PM
d. troy castro  is offline
Posts: 15  -  iTrader: (0)
when the volume pedal is in front of the distortion/ od pedals in a chain, it creates the same effect as rolling off your guitars volume knob, and controls the amount of signal going to the gain, so it sounds clean when open but full blast when he opens it up.
hope that helped
Old 04-12-2009, 07:18 AM
iainharvey42  is offline
Posts: 2  -  iTrader: (0)
You could use the wet box from gig rig. It mix's the clean signal with the distorted one and is controlled by a pedal.
clean tone, distorted tone, ernie ball volume pedal, keri kelli
the volume pedal dwswift Gear and Equipment 34 12-21-2010 09:59 AM
Volume pedal kpinks Gear and Equipment 5 08-26-2008 06:35 PM
WTB: Volume Pedal Guitarmiester Classified Ads: Guitars and Gear 0 02-01-2008 04:28 PM
FS: Line 6 MM4 pedal, Morley PVO volume pedal luther Classified Ads: Guitars and Gear 0 06-17-2005 12:55 PM
Expression Pedal? - which volume pedal will work? mikek Gear and Equipment 1 01-02-2001 08:39 PM
