Gear and Equipment
lead boost
Gear and Equipment
03-11-2006, 02:05 AM
unhooked
Posts: 53 - iTrader: (
lead boost
OK, I am in the market for a new or used amp. Wondering what everyone else uses. When I play live, it seems that when we get to the guitar lead (I play covers), that everyone seems to get louder, so I need a lead boost. I used to have a dsl 40 watt combo, and it had one, but I sold that.
I have been thinking either the jsx, or something by marshall....either a 2x12 amp, or a head and a 4x12 cabinet...
Its gotta have a lead boost....
unhooked
Find all posts by unhooked
03-11-2006, 07:40 AM
Ant1981
Posts: 2,181 - iTrader: (
Re: lead boost
I know what you mean, I get the same. It's not that everyone gets louder, it's just that the solo gets lost in the mix and needs to be louder.
No need to change your amp, honestly.
Get an MXR M-133 Micro Amp pedal and put it in the effects loop.
There is the usual on off foot swtich and one gain control. The gain doesnt place anymore distortion to your sound, it just gives you the desired volume boost!
Job Done!
Ant1981
Find all posts by Ant1981
03-11-2006, 04:04 PM
learningtolive
Posts: 178 - iTrader: (
Re: lead boost
Does the effects loop boost actually work cleanly? I tried this with a Marshall Bluesbreaker 2 boost in my DSL loop and I lost a lot of gain and tone, though did indeed gain volume.
I heard the Carl Martin Hydra Boost was good, can anyone clarify this, preferably using it in a high gain/metal context? Just think Bodom, Trivium, etc. Any other recommendations would be cool too.
Cheers, Mark.
learningtolive
Find all posts by learningtolive
03-11-2006, 11:06 PM
Xavier 7
Posts: 176 - iTrader: (
Re: lead boost
Well, if you want a new amp then you really can't go wrong with a Mesa/Boogie Nomad 45 which has a solo boost that is controlled by the footswitch. If you're really deadset on something else then I'd just get an equalizer pedal and set it to max.
Xavier 7
Find all posts by Xavier 7
03-12-2006, 12:05 AM
EL-CeeDee
Posts: 484 - iTrader: (
Re: lead boost
learning:
I have a carl martin hydra boost....
However, I use it in a totally different fashion. to boost the distortion for my
YJM strat
. It does so pretty clean. so I think that placing it in an effect loop would be pretty much ok. You'd push the poweramp section harder, thus making the distorted sound louder. Should work fine. plus,.. it's pretty affordable!
EL-CeeDee
Find all posts by EL-CeeDee
03-12-2006, 07:11 AM
wallopwallop
Posts: 330 - iTrader: (
Re: lead boost
I use a
Seymour Duncan
Pickup Booster for a boost on my clean solos (adds up to 25db of pretty transparent gain) and an original issue Marshall Bluesbreaker for dirtier stuff.
If you are set on a new amp then go for it but there are cheaper solutions to your problem without having to go all in on expernsive equipment.
wallopwallop
Find all posts by wallopwallop
03-12-2006, 07:14 AM
wallopwallop
Re: lead boost
http://www.award-session.com/solobooster.html
Or this!
wallopwallop
03-12-2006, 10:02 AM
Ant1981
Re: lead boost
The MXR Micro Amp pedal in the effects loop gives a very clean boost indeed. Just more volume without distorting your signal.
I too was looking at new amps, but there wasn't anything better out there that I would be happy with. The best of the bunch are single or two channel. The three channels have alot of redesigning needed in my opinion.
The boogie solo boost on the amps are good, but its a more expensive route to take.
Honestly, the Micro Amp pedal will put a smile on your face and give you what you need, for very little money.
Ant1981
03-12-2006, 12:02 PM
learningtolive
Re: lead boost
wallopwallop
Or this!
That looks absolutely perfect! I am slightly loathe to order one sight unseen, but the reviews seem pretty reassuring.
The fact it is made with the fx loop in mind makes me even more curious, not to mention the excellent price.
Ho-hum.
learningtolive
03-12-2006, 12:56 PM
Ant1981
Re: lead boost
http://www.jimdunlop.com/products/el...ucts/m133.html
There's the MXR Micro Amp, I use it for solo boosts as do many others. Just pure volume boost with no colouring your tone or adding distortion. Put it in the effects loop and rock!
Ant1981
03-12-2006, 02:59 PM
wallopwallop
Re: lead boost
learningtolive
Ho-hum.
I actually own one on of these too (Jeez I need to thin my equipment down)!
I use it in the FX loop of my Rivera Combo. It's built really well and works precisely as intended.
Order with confidence. Award Session stuf is built to last!
wallopwallop
03-13-2006, 12:26 PM
Drew
Posts: 4,538 - iTrader: (
Re: lead boost
The problem with using a booster pedal in front of your amp is that it'll give you a gain boost, but not much of a volume boost because really all you're doing is hitting your preamp tubes harder, causing them to overdrive and further compress.
Sticking somehting in the FX loop, as Ant suggests, is a better option, although I've never tried this so I can't recommend it or speak from experience.
An amp with a third channel you can set specifically for lead sounds, or one with a footswitchable clean boost, is really your best bet. I LOVE my Nomad, but you sound like you're looking for something more Marshall-y, so maybe it wouldn't work for you. Mesa's Stilleto is more Marshall in character, so that's worth a shot. One of the TSL's might be worth a look, and I believe the JSX has three channels and also could work for you.
Drew
Visit Drew's homepage!
Find all posts by Drew
boogie nomad
preamp tube
seymour duncan
yjm strat
fulltone fat boost where to place in chain
how to get that allan holdsworth lead tone
on powerball is contour reverb the mid boost?
who plays vht pittbull ultra lead?
how to bias a marshall super lead
good volume boost stomp box??
adamcbest
Gear and Equipment
12:56 PM
5150 with boost pedal good for lead work?
Jupiter
Gear and Equipment
09:36 PM
Looking for a boost...
Jammy
Gear and Equipment
01:47 PM
Lead Boost with an EQ pedal - What are your settings?
revsharp777
Gear and Equipment
02:14 PM
Lead vs. Rythm
kirk
Gear and Equipment
07:22 PM
05:00 PM
