Old 07-27-2009, 08:15 AM
bucket_bot  is offline
Posts: 224  -  iTrader: (1)
Legacy Master Volume Mod
For anyone interested I recently carried out this mod successfully on my Legacy 1.
I documented it on the Carvin BB for the benefit of others who may be interested.
It was not difficult to do and was IMO worthwhile.
See link below:
http://www.carvinguitars.com/bbs/vie...27a5350eb079fb
Old 07-27-2009, 12:07 PM
teokiatuan  is offline
Posts: 425  -  iTrader: (0)
Re: Legacy Master Volume Mod
very cool!
how much?
Old 07-27-2009, 02:55 PM
Originally Posted by teokiatuan View Post
very cool!
how much?
If you mean the cost of the parts.....around £15 UK.
Old 07-28-2009, 09:00 AM
sounds good, cheaper and gentler on the tubes than an attenuator...
how does it compare to the mv on the legacy II?
Old 07-28-2009, 09:09 AM
Pretty favourably I would say as far as the Lead channel is concerned, however it does result in some breakup on the clean channel if you set the MV less than around 30%.
However all in all the mod gives the amp a lot more flexibility and you lose nothing by doing it as with the MV dimed to 100% the amp behaves exactly as before.
However I would still say that of the 2 amps I still prefer the Legacy 1.
Old 07-28-2009, 09:27 AM
im thinking of installing it on my amp now
problem is i can only install it at the back, not a fan of the front panel installation...
hmm....
Old 07-28-2009, 09:37 AM
Not really a problem.
Should be room to fit the Pot opposite to where I fitted mine.
On the rear panel this would be in the area of the serial number sticker on the Right hand side near the power cord connection.
Old 07-28-2009, 10:19 AM
ah i see, a bit of an hassle to adjust it though
ok i'll stop being a picky bugger
Carvin really should have done this on the L1 in the first place.
Old 07-28-2009, 10:37 AM
No probs.....picky is good!
It looks much better now I have a matching Chicken head knob from Carvin.
Alternatively you could mount it where I have and fit a very small round knob of a similar colour to the panel then it would hardly be visible if that is your concern?
Old 07-28-2009, 11:19 AM
eviltwin  is offline
Posts: 1,629  -  iTrader: (0)
Images: 6
How about mounting this as an outboard footpedal? In stead of a front mounted knob, you'd have a rear jack!
Old 07-28-2009, 11:34 AM
Exclamation
Not sure of the voltages passing through that part of the PCB so possibly not a good idea?
Also the mod requires a dual pot so not quite as simple as just replacing it with a jack.
Old 07-28-2009, 12:22 PM
ah yes, i never thought of going small, thanks for the idea
its looking very tempting right nowww
Old 07-28-2009, 12:27 PM
eviltwin  is offline
Images: 6
1) I'm not suggesting running 600V through a volume pedal, there must be a way to keep signal, and power circuits separate. I'm pretty sure the current mod already does that, otherwise if the chickenhead knob fell off, that pot would become seriously dangerous
2) perhaps I wasn't clear enough, when I said pedal I meant a rocking CC-type or volume pedal, NOT a switch.
A Dual pot could become stereo jack to stereo volume pedal. Such a pedal would add some cost to the mod, but it would protect the integrity of the front panel and add a cool feature.
Old 07-28-2009, 01:01 PM
By all means go ahead & give it a go?
To be honest I'm pretty sure there is not 600V running through the Pot or Richard Hasslebrock would not have suggested the mod.
As you say that would be dangerous.
Personally I don't have a problem with an extra Knob on the front panel.
legacy master volume
Lower Down Legacy Amp Volume Level wareyha Tech: Setup, Repairs and Mods 3 12-03-2008 07:54 PM
My Amp doens't have a Master Volume (Carvin Legacy) Silverburst Gear and Equipment 11 04-18-2007 12:59 PM
Carvin Legacy head, 3 volume pedals for sale DavejWeiner Dave Weiner Official Forum Archive (SEE NEW LOCATION) 10 01-04-2006 12:26 AM
Optimum balance in master volume for tube-iness - Pre and po tomizm Gear and Equipment 1 02-12-2002 07:19 AM
Carvin Legacy combo volume fade - Anyone know what causes th pri0531 Gear and Equipment 3 01-24-2002 02:32 PM
