I usually play 09-42 gauge GHS, but I want to order some LTHB Ernie Ball 10-13-17-30-42-52 packs so I can detune my RG560 to either C or C# standard. I have a couple questions:
1) Will the unbalanced string tension warp my thin (original) Wizard neck?
2) With this gauge, what's an ideal tuning? I normally use 09s in either E or E
1) Should be fine... i'm tuned to C standard on an RG550 with custom gauges; 11 at the bottom, 54 on top. Neck's still fine after major readjustments to the truss, saddles, and
bridge angle. Still using 3 springs too!
2) standard C# would "feel" proper with the 10 - 52 gauge; standard C might be a little flabby... maybe drop C would balance the 52 with the rest?
Reg
