Old 07-18-2001, 12:47 PM
Gabe Nickelson  is offline
Posts: 961  -  iTrader: (0)
Little Alligator Volume Pedal Problem... - issue or not?
Well, I picked up one of these on vacation. *I've always wanted to own a volume pedal, now I've got one.
Anyway, my problem is that even when the volume pedal is all the way down (off), I still can hear my guitar ever so slightly through my amp. *I have the POT tuned all the way down too. *I also noticed that when I push the pedal forward slowly its not gradual... when the volume kicks in it's pretty loud. *Could this be a problem with the optics? *Maybe the adjustment pot?
Thanks,
Gabe
Old 07-18-2001, 12:53 PM
jemsite  is online
Administrator
Posts: 9,272  -  iTrader: (5)
Images: 11
sounds like the pot is not allowing it to fully shut off. I guess it could be the pot, optics or something else. I'd email morley or do a swap. The volume swell should be gradual, like on my PVO... glen
Old 07-19-2001, 05:34 AM
J Todd Beachler  is offline
Posts: 248  -  iTrader: (0)
Gabe,
Call Bill Wenzloff at Morley Mon - Fri between
8:00 am and 3:30 pm central time at 1-800-284-5172. *He will be more than helpfull!
Old 07-19-2001, 02:51 PM
bob oakman  is offline
Posts: 922  -  iTrader: (0)
My guess… just a guess on the non-gradual volume problem… The high gain setting on the preamp is introducing so much compression that as soon as it gets a signal and the gate lets go, its reproducing massive level. To test this, try it with a clean setting. If it still happens it’s the pedal. If not, I don’t know what to do to fix it. Maybe messing with the gate settings.
Old 07-20-2001, 01:28 AM
Bob, did you ever get your Bad Horsie adjusted? *Just wondering on how it worked out and if you like it better.
bob oakman, volume pedal
