Old 05-20-2008, 08:01 PM
AustinPlaysGuitar  is offline
Posts: 99  -  iTrader: (0)
Locking Bridge, NOT Trem
hey! im new here. anyway, im looking for a bridge w/ locking tuners but not a tremolo. b/c i am currently building a project guitar and the body is an Ibanez rg321 and i dont want to mess w/ routing out a cavity and all for a tremolo but i need a locking bridge b/c my nut is locking. any help guys?
Old 05-20-2008, 08:35 PM
ryanb  is offline
Posts: 1,457  -  iTrader: (0)
Re: Locking Bridge, NOT Trem
You don't necessarily need a locking bridge, just a bridge with tuners. But that probably doesn't help any. The one that comes to mind in the EdgeFX, but you'd have to be really lucky to find one.
Why not just replace the nut? (or take the locking pads off, which I don't recommend)
Old 05-20-2008, 08:36 PM
elcid  is offline
Posts: 8,718  -  iTrader: (12)
Why do you need a locking bridge if you are building a hard tail guitar?
Old 05-20-2008, 08:44 PM
well. the nut space on my neck is huge and its the standard locking nut size :[
Old 05-20-2008, 08:51 PM
ColinMmmmm  is offline
Posts: 1,068  -  iTrader: (1)
Schaller makes one - but you'd have to fill the holes for your bridge and drill new ones. Plus it's made for guitars with a bit of a neck angle to them - so you might have to shim the neck . . . But I've never played around with one. Check out Warmoth - they sell 'em. Although if I were you I'd just get some locking tuners and replace the nut.
Old 05-20-2008, 09:03 PM
the nut isnt really the problem unless anyone knows where i can find a nut the size of a locking nut
Old 05-20-2008, 09:16 PM
on my neck, there is no nut. just the space for a locking nut which is much bigger than a normal nut. and unless i can find a nut that is the same size as a locking nut w/o it being locking. then i need to find a fixed locking non-tremolo bridge.
Old 05-20-2008, 09:36 PM
anyone else?
Old 05-20-2008, 09:40 PM
I'm sure there are ways you could fill in the space . . . it'd be easier than finding a locking bridge . . .
CosmicDebris  is offline
Posts: 3,216  -  iTrader: (4)
A wilkinson roller nut might take up the space where a ibby locker would go. I will bring my digi calipers home tomorrow night and get some specs for you.
Old 05-20-2008, 09:43 PM
a few things: whats an ibby locker and digi caliper?
and i looked at the roller nut but it said not for angled necks and mine is angled :[
Old 05-20-2008, 09:47 PM
example? is there a way even with that much tension on the strings that it wont break?
Old 05-20-2008, 11:11 PM
any other suggestions?
Old 05-20-2008, 11:15 PM
Petie  is offline
Posts: 2,877  -  iTrader: (0)
Here ya go:
http://kahlerusa.com/home.html
Go to "Products" then "Fixed Bridges" and select the 3300 Guitar Fixed Bridge.
If it's good enough for Dave Mustaine and Marty Friedman...
Old 05-20-2008, 11:16 PM
toshiro  is offline
Posts: 1,812  -  iTrader: (11)
http://www.allparts.com/store/nuts-s...23,Product.asp
dave mustaine, fixed bridge, ibanez neck, ibanez necks, locking bridge, locking nut, locking tuners, marty friedman, neck angle, nut pads, paul gilbert, trem block, tremolo bridge
Don't 2003 JEM's Have Locking Bridge Posts? Robotechnology JEM and Universe Guitars 4 04-03-2004 02:00 PM
Trem angle wangbar Tech: Setup, Repairs and Mods 8 11-25-2003 06:37 PM
question from first time double locking trem user al885 Tech: Setup, Repairs and Mods 8 08-06-2003 02:02 AM
locking nut with fixed bridge? zEr0 Gear and Equipment 8 02-09-2003 01:14 PM
