so i got a problem, i ordered a loop switcher and im totally confused as to how to hook it up....heres how it runs...the return is connect to the output on my MXR 10 band EQ then that runs to my Boss DD-3 then the send runs into the input on the DD-3 thats the effects loop. the input on my amp runs down into my rocktron hush that runs into the out of my TS-9 that runs into the out of my SD-1 then the input of the SD-1 goes to my guitar...
The
looper is a 2 loop pedal by loop master, it has a out, and an in on the sides and on the top is receive/send for loop 2 and the other side has receive/send for the loop 1, how do i hook all this up?i hooked it up fine with it all running to the input of the amp but it didnt sound the same so im clueless.
i wanna keep the dist/hush in front and the other 2 in the loop and use the looper to switch the sets on and off is this possible?
