Gear and Equipment
Low wattage tube amp recomendations.
Gear and Equipment
02-08-2007, 02:45 PM
Rotti
Posts: 3,341 - iTrader: (
Anyone have any suggestions for good low wattage (12-25 watt range)
tube amps
that are reasonably priced? The amp would be used for playing live gigs in small clubs with a mic in front of the amp. Music styles are blues, rock, classic rock and some old school
heavy metal
every now and then.
Rotti
Visit Rotti's homepage!
Find all posts by Rotti
02-08-2007, 02:54 PM
voodoo_child
Posts: 716 - iTrader: (
Re: Low wattage tube amp recomendations.
2nd hand mesa F30? They arent cheap here, but I presume they are reasonably priced in Canada?
voodoo_child
Find all posts by voodoo_child
02-08-2007, 03:00 PM
Rotti
Thanks I'll look into it.
Rotti
02-08-2007, 03:08 PM
Xerack
Posts: 54 - iTrader: (
You might check out Satriani's new amp:
http://www.***************.com/item--i-PEV-JSXMINI.html
not quite as many watts as you were looking for, but sounds like this might be a very cool little amp!
Cheers,
Xerack
Xerack
Find all posts by Xerack
02-08-2007, 03:09 PM
Xerack
haha..oops, didn't realize that would happen. The link was from american musical supply ; ).
Xerack
Xerack
02-08-2007, 03:45 PM
the.godfather
Posts: 3,593 - iTrader: (
Do a forum search, low wattage tube amps have been discussed alot in the last year.
Laney LC15, LC15R, VC15
Peavey Valveking
Royal 8
Ibanez Valbee
For a
, its Laney all the way for my money.
the.godfather
Find all posts by the.godfather
02-08-2007, 08:07 PM
pawel
Posts: 2,656 - iTrader: (
The new Mesa Express would be an interesting one to look at as well. If you wanted to move up in price range, the Suhr Badger seems very cool, considerably more expensive than the other recommendations though.
pawel
Find all posts by pawel
02-08-2007, 08:17 PM
elcid
Posts: 8,720 - iTrader: (
Im with godfather, search the forums.
Personally I like my orange AD30
elcid
Find all posts by elcid
02-08-2007, 09:05 PM
David McCarroll
Posts: 2,049 - iTrader: (
If money is not an object you may want to have a look at the smaller Cornfords. Marshall also do a thing which appears to be called an 18watt Handwired (catchy eh?) which would be a little spanker - cute too, but not exactly budget!
David McCarroll
Find all posts by David McCarroll
02-08-2007, 10:37 PM
Rotti
Well money is always an issue unfortunately. I'm just looking for things out of the ordinary that I might not have heard of.
Rotti
02-09-2007, 12:44 AM
Kontalonis
Posts: 1,006 - iTrader: (
Dunno if you need dual channel, but carvin has a pretty nice single channel 16 watt amp. You can also switch it down to 5 watts. It comes with a celestion V30 stock and has a great vintage look:
It will run you about 430 shipped which i didn't think was that bad.
Kontalonis
Find all posts by Kontalonis
02-09-2007, 01:09 AM
Rotti
Now thats cool! I'll look into that for sure.
Rotti
02-09-2007, 09:40 AM
jim777
Posts: 8,943 - iTrader: (
Don't throw rocks or anything, but the 5 Watt Epiphone Valve Jr. is $100 bucks, and sound pretty good on a 4x12 cabinet! There ae lots of mods out there for them as well, so you can customize it for yourself down the road if you get a little bored of it. It actually might be perfect for the kind of music you want to play through it, and leaves you $$ room for an EQ or a speaker upgrade or whatever if you want.
jim777
Find all posts by jim777
02-09-2007, 12:55 PM
Rotti
Hmm, I know someone locally who has two Marshal 4x10 cabs with Celestians for sale cheap. Maybe two Valve Jr. heads and those two cabs would be an interesting setup.
Rotti
06-26-2007, 01:45 PM
riggaz
Posts: 17 - iTrader: (
I recently bought a laney lc15r and did a couple of mods, i put some new cryo valves and a jensen p10r alnico speaker in and it has transformed it touch sensitive with crystal clear highs and a lovely sweet tone, it sounds amazing, might not be ballsy enough for a gig on it's own but with a decent mic should be cool. I would try and find a good 30 watt'er preferably with 2 x 10" or 2 x 12" drivers in it, great for practice / recording and will kick on at a gig. If you can afford it and feel like having something special modify it with some new cryo valves and a couple of jensen p10r / p10q for 2 x 10" or Celestion G12 Century Vintage speakers for a 2 x 12" at 101db per watt these go loud but they also sound superb.
riggaz
Find all posts by riggaz
engl screamer
heavy metal
ibanez valbee
music store
peavey valveking
tube amp
tube amps
how to set up a tube screamer
amp wattage is less then cab wattage
how to tell when preamp tube goes bad
how to turn on and of a tube amp
which low wattage tube amp?
Low power/low wattage tube amps
slugman
Gear and Equipment
02:17 PM
Tube tube tube. Help me out please.. Marshall JCM2000DSL
SHsu516815
Gear and Equipment
29
06-26-2003
05:40 PM
Calling All Tube amp experts! (tube emergency?)
Greg RG7
Tech: Setup, Repairs and Mods
07:45 AM
Legacy the unrelenting tube eater! - Getting ready for solid
Darin W
Gear and Equipment
09:36 AM
Real Tube - I found a great pedal
jeff l
Gear and Equipment
12:21 PM
05:10 AM
