running 8ohm outs from your amp to 16ohm impedence cabinet is not going ot hurt anything.It simply lowers your volume.IF you plug into a 4
ohm cabinet, you will screw up your amp because your amp needs to see a minimum impedemnce of 8 ohms.
You will also lose some high end when running into a cabinet that has higher impedence than the optimal rating of your amp
