Old 01-16-2004, 01:43 PM
SuperJemBoy  is offline
Posts: 292  -  iTrader: (1)
Marshall 8004 Power amp - any good?
Well, the subject sums it up. Is it any good? theres only one review on harmony central and I need to know soon because its a deal 2nd hand. I would most likely be using this with a POD or similar.
Thanks!
Joe
Old 01-16-2004, 05:49 PM
gkelm  is offline
Posts: 1,564  -  iTrader: (8)
Is that the single rack space, gold face, SS model? Had one a while back (or was it the 8008?). It should be really cheap...I couldn't say it sounded good, but can get you by if you're on a budget. I found he ADA Micro-Tube power amp to be a bit warmer sounding, and then ended up with a PV Classic 50/50...great amp for $200-250 used. With a POD it might be OK since you just want a basic clean tone. All the best.
Greg
clean tone, power amp, rack space, tube power amp
