Old 07-29-2009, 12:32 PM
Hunter Wingate  is offline
Posts: 39  -  iTrader: (0)
Marshall amp cabinet question
Ok, so my friend is trading me a Marshall 1960b cabinet for a Galveston guitar/bass double neck that I have. This is such a good trade that I really don't care that I don't have a Marshall amp head.
I'm relatively new to amp stuff, so here's my question: Will I be able to hook up my Peavey amp to this cabinet?
Old 07-29-2009, 12:40 PM
skins345669  is offline
Posts: 835  -  iTrader: (0)
Re: Marshall amp cabinet question
Impedance matching is the key.
Low to high, you'll be fine.
Don't run a higher impedance head into a lower impedance cab though, horrible things happen to your transformer.
Old 07-29-2009, 12:56 PM
6fingers  is offline
Posts: 3,167  -  iTrader: (0)
Reviews: 63
Do you really believe we have crystal balls?
How could we know wich Peavey you have?
Grrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr
Old 07-29-2009, 12:59 PM
That's what I meant to write. Damn typos.
Old 07-29-2009, 01:00 PM
Hmm, thanks, but could you try to explain please? and how would I know if my amp is higher impedance? Sorry, I'm just new to this.
Old 07-29-2009, 01:05 PM
It'll say just above the jack sockets, where you plug the cables in. ie output of your amp to input of your cabinet.
You know what? For this post I can't be bothered with punctuation.
Old 07-29-2009, 01:06 PM
6fingers  is offline
Reviews: 63
Well as you're telling us you're new to that I have to tell you there's something called MANUAL.
Some people think it's a myth,some it's garbage but I can tell you it's your best friend.
Give it a chance you'll never regret!
Old 07-29-2009, 01:08 PM
It's a Peavey Express 112.
Old 07-29-2009, 01:36 PM
GLG421  is offline
Posts: 323  -  iTrader: (3)
Not sure of the Peavey amp's out put, but a 1960b in standard configuration should handle it with no problems
Here's what sweetwater has to say in their description of a new 1960B
To ensure the ultimate in flexibility, the 1960A (angled) and the 1960B (straight), is switchable between Mono (4 or 16 Ohms) and Stereo (8 Ohms per side). The two Mono impedance options provide extra amp matching capability while the cabinets' stereo capability makes them ideal for rack systems which typically run in stereo.
So if the 1960B has these impedance options on the back, you should have no problems matching it up with your amp, if it has fairly standard output jacks.
Old 07-29-2009, 01:55 PM
Alright, thanks. I'll be glad if it hooks up just fine. :]
Old 07-29-2009, 02:20 PM
Just make sure you do your impedance matching first.
Old 07-29-2009, 04:56 PM
GLG421  is offline
Also make sure you are using Speaker cable, and not instrument cable to connect the two.
Instrument cable can not handle the output.
Old 07-29-2009, 05:45 PM
Oh, lol, thanks. If you hadn't have said that I'd be plugging an instrument cable in, lol.
What's the major difference between the two anyway?
Old 07-29-2009, 05:48 PM
Speaker cable has a thicker core, less resistance, so can handle more current.
Marshall cabinet troubleshooting martyfriedman86 Gear and Equipment 3 08-07-2008 10:17 AM
Marshall Cabinet 4X12 Handle Rivets. stratosqueeg Tech: Setup, Repairs and Mods 0 09-24-2007 05:18 PM
FS: Marshall 1922 2x12 Cabinet the.godfather Classified Ads: Guitars and Gear 1 01-05-2007 12:40 PM
Marshall 1960B 4x12 JCM800 era cabinet red5 Classified Ads: Guitars and Gear 2 10-02-2006 12:59 AM
What cabinet would you recommend? - The Marshall 4x12 aint c Patrick Deno Gear and Equipment 9 06-02-2001 03:12 PM
