Marshall AVT Replacement Pre-amp Tubes?? - Jemsite
Old 09-29-2004, 08:28 PM
jemaholic  is offline
Posts: 2,848  -  iTrader: (14)
I've got an AVT 150 head and was wondering if anyone has changed out the 12AX7 preamp tube for a hotter one?
In theory it should be just like the all-valve heads, right? Not much on a google search either.
Sovtek makes some tricked-out pre's as well as some company in China.
Thanks.
Old 09-30-2004, 10:45 AM
jeff l  is offline
Posts: 554  -  iTrader: (0)
Hotter than a 12AX7? Nah, the AX7/ECC83 is as hot as they come. You could try swapping out a few different ones to see if it helps.....if you can even find the damn thing in there among the SS components &amp; ribbon wires.
Don't expect your AVT to sound like an all tube head regardless of the Marshall ads. All tube and hybrid/SS amps are totally different beasts.
Old 10-01-2004, 10:56 AM
Thanks Jeff- you are right they are different beasts. My old Marshall heads are easy to soup up- and I believe the AVT can be too- just haven't found out how yet.
Mine may be the first!!
preamp tube , tube head
Replacement tubes (power section) for JCM900 SL-X metalguy Gear and Equipment 9 06-12-2012 01:05 AM
replacement amplifier tubes Satchriossi Tech: Setup, Repairs and Mods 1 01-30-2009 09:01 PM
Marshall Tubes? megadeth Gear and Equipment 20 03-19-2005 12:30 AM
Replacement tubes for Marshall preamp stage jemaholic Tech: Setup, Repairs and Mods 3 10-11-2004 05:02 PM
Can these preamp tubes be used for my Marshall amp??? - It's firegarden Tech: Setup, Repairs and Mods 2 12-17-2001 11:57 AM
Powered by
