Gear and Equipment
Marshall JCM 800 Cab versus 1960 standard cab
Gear and Equipment
02-13-2006, 07:30 AM
jemke
Posts: 318 - iTrader: (
I recently bought a 4x12' JCM 800 cab after A/B'ing them.
I first tested the new cab with a crunchy jcm 800 amp. It was a huge sound, lots of bas, impressive.
Then I tested the JCM 800 cab with exactly the same settings. The first impression was a more midrange focus and more detailed sound and more presence. After playing both for about 1/2 hour I realy liked the 800 sound because it is realy an into your face sound. It was a real different tone.
As far as I know the JCM 800 cab is the most recent model (1987-1990) because it can handle 300W so I suppose it has the same speakers as the standard 1960 cab.
Why the huge difference in sound?
Am a wrong and are the speakers different? Is it an overal different contruction and choice of material that makes the difference?
jemke
Find all posts by jemke
02-13-2006, 09:43 AM
Ant1981
Posts: 2,181 - iTrader: (
Re: Marshall JCM 800 Cab versus 1960 standard cab
Maybe the JCM800 cab is a bit more 'run in' or they could have the G12M70's.
Ant1981
Find all posts by Ant1981
02-13-2006, 06:37 PM
red5
Posts: 2,639 - iTrader: (
G12M70s were only offered in cheap Marshalls something like 20 years ago for a limited period of time. They sound just like the G12M-75s as well, except they are rated at 75 watts. I doubt that G12M70s would sound significantly better than 75s when they are a cheaper model of the same speaker.
But I am going to guess the speakers were replaced. I have 2 JCM 800 cabs, both with G12M-75s and I am not the only person who thinks the G12M75s give Celestion a bad name. They do get a good Zack Wylde like tone, but they suck clean. I hardly ever used my straight cabinet, and I put Classic Leads into the angled cabinet and I sure as hell will not use the straight cabnet again unless I put some V30s or Classic Leads in that!
red5
Find all posts by red5
02-13-2006, 07:08 PM
bluealien
Posts: 959 - iTrader: (
When I use to play Marshall, I never had a 2 cabinets that sounded the same... so it just might be the the slight differences in how it was built, wood, speaker age, not remebering now is there insulation in them too?
bluealien
Visit bluealien's homepage!
Find all posts by bluealien
02-13-2006, 07:24 PM
red5
Not in mine - typical closed back cabinet (not sealed or whatever they call it when the back is permanently attached like the old Fenders).
red5
02-13-2006, 09:30 PM
Ant1981
red5
Do you think JCM800's are cheap? Guess what speakers are in JCM800 combos? G12M70's
Ant1981
02-14-2006, 01:05 AM
red5
After they phased them out and switched to the G12M75s at least they were only used in Marshall's budget amps. This is after the JCM 800 era, so 15 years ago is more accurate. But I have never seen a cabinet with G12M-70s, only 65s or 75s.
Guess what speakers were used in the golden JCM 800 era? G12M-65s. Then came the G12M70s for a brief period and then the G12M75s after that. I remember you have a later 80s JCM 800 like a '89 or something? Must be a 4210 (I don't think they switched to 75s on them).
01:13 AM
red5
02-14-2006, 03:14 AM
jemke
Thanx for the replies. I think that I'm going to open the cab and see what speakers are realy into my cab!
just have to an apprpriate find a screwdriver (just moved and everything is still in boxes, hehe)
jemke
02-14-2006, 12:17 PM
red5
jemke
I am interested to hear what they are. I am guessing they have been upgraded significantly
red5
02-14-2006, 04:21 PM
jemke
They are G12T-75's
jemke
02-14-2006, 04:47 PM
jemke
So are they original or not? What's the difference with G12M-75 or are they the same?
jemke
02-16-2006, 02:11 AM
red5
jemke
They are the same, except for possible minor differences. I am pretty sure they are still using the same mold for them as they did back then (some of the molds got wrecked and they had to make the molds again - the G12M-80s were one of them, so the new mold model is the Classic Leads).
red5
how can i tell thin or standard neck prs
what nut does my indonesia squire standard have?
what is the standard string gauge on a les paul
whats better les paul standard or sg standard
marshall jtm 30 how to connect effect pedal to send return loop
FS/FT: '94 Marshall 1960 slant cab - Greenbacks/V30s
gkelm
05:05 PM
WTB: Marshall 1960 Lead Cabs
etuor
03:56 AM
FS: Marshall 1960 Vintage full stack
Gabe Nickelson
12:53 AM
Marshall 1960 anniv. cabs: Same as 1960A??
SilverSurfer2
Gear and Equipment
02:09 AM
Bogner shiva amps versus marshall...
jemke
Gear and Equipment
06:04 PM
04:07 PM
