Old 08-11-2004, 07:27 PM
michblanch  is offline
Posts: 1,159  -  iTrader: (4)
Mesa Question
I dont post often , but I read all of the ads. And have purchased thru the board.
Hope this is in the right forum.
I have a found a Mesa .22 Cal. for sale. But I am not familiar with this amp. I have played the Nomad 55. But it is too much amp for my home.
How is the tone? How does it sound? I hope you guys can help me here. And I hope I'm not asking a dumb question.
Thanks.
Old 08-11-2004, 09:30 PM
bpd111  is offline
Posts: 1,628  -  iTrader: (7)
A friend of mine had a .22 and I loved it. It wasn't too loud. It wasn't loud enough when playing with others.
Old 08-11-2004, 11:47 PM
frankfalbo  is offline
I think I've read certain reviews that say it can be a bit muddy, and I have not found that to be the case. So if you hear that take it with a grain of salt. It could be that I've played ones with good clean preamp tubes, or that I know you have to keep the bass knob backed off around 5 or less on most Boogies. I imagine you'll get great results from it. All Boogies require tweaking. Play with preamp tubes, both ones that are touted as "high gain" and ones that are "cleaner" sounding. Preamp tubes are cheap and they make a big difference in the old boogie MK style preamp. It should have plenty of volume with an extension cabinet if necessary. Even Mesas can only move so much air through a 1x12. As for the overall tone, I found it to be very MKII friendly. Not that it sounds just like a MKII, but more like if you like a MKII sound, you'll probably like the .22. If you like the MKIV lead sound, and you liked the Nomad and the Rectifiers, then you may find you have to use a pedal in front of it to get what you want out of it.
Old 08-12-2004, 06:10 AM
Mr Orange  is offline
Posts: 448  -  iTrader: (0)
Had one, but traded it for a .50 Caliber+ head.
It was a nice amp, though. Very easy to record, not very bassy but who needs bass anyway, that's what the bass players are for. I gigged the thing and it was ok for small gigs, loud for such a little amp. Just add an overdrive pedal and you're pretty much set.
But it's not everyman's amp, it's quite midsy compared to the Nomads IMNSHO, but mids are good (bass 3, mids 8, treble 6... will help you cut thorugh in a band situation). Try before you buy...
Old 08-12-2004, 09:56 AM
Drew  is offline
Posts: 4,538  -  iTrader: (4)
haha, imnsho. Priceless, man.
I wouldn't be at all worried about gigging with a 22-watt mesa. I owned a rocket-44 for a while, which, while granted pushed about double the wattage, also never was turned up more than three or four for the loudest gigs I ever played, and I've played with some pretty loud bands. And my Mesa Nomad-45 may actually be louder than my old TSL-100 driving a recto 2x12 cab- haven't had the balls to completely unleash it yet, but it's capable of devastating output.
And anyway, there'x a lot to be said for an amp that can be pushed fairly hard for a gig, without moving so much air that it'd be unfeasable to mic it.
As for the "muddy" thing, there's two types of guitarists, I've noticed. Those that like marshall-style crunch, and those that like mesa-style chunk. I've always felt that, even the most bass-eavy marshalls I've ever played, the emphasis was really more on the lower mids than the bass- the lead channel on the TSL was the closest I've ever heard, but even with the deep switch enguaged, I'd say channel 3 modern on my nomad has noticeably moer depth, and thats a MUCH clearer sound than your typical Recto grind. So, it's really a taste thing- if you prefer marsall sounds, then even with the bass cut way back, the mesa will seem "muddy." But, if you like mesa's low end, the marshalls will sound fairly weak in the bass.
I will say that it's a little easier to get a marshall to cut through a mix, because of the weaker low end, but as for myself, i think it's worth the extra trouble, and when you're recording (currently bandless, so this is the only time i ever ha a mic in front of mine), a slight eq slope below 120hz will more than compensate.
so, this was a long, rambling post that didn't say much, but i hope some of it helps.
-D
Old 08-12-2004, 11:21 AM
bammbamm  is online
I have one, I love it and doubt I'll ever sell it.
For me it is the perfect combo.
If you have the one with the EQ on it, that can make all the difference.
There are 3 modes for the EQ; always on, lead mode on, and off I like that option for the simple fact that you can add in enough mid boost for a lead tone. Mine is set as a clean and dirty setting, the amp isn't really a dual channel amp, it is a single channel boost, but once you have mastered dilaing it in, you hardly know the difference.
If you decide to get it, let me know, I'll email you a scan of my settings sheet from Mesa.
Very versitile little amp !
Bamm
extension cab, mesa nomad, overdrive pedal, preamp tube
