Re: Mesa Triple Rectifier Help Needed
To try and give a little more helpful advise...let me first make sure that you are only getting the hum and noise when you are using the loop. As for the hum, that could also be caused by a ground loop if you have some pedals in the loop. Try plugging a cord just into the send and return of the loop and see if you're still getting the problem. If you still are, and I would imagine you will, you are probably dealing with a bad tube in the V4 position. Try swapping out that tube and seeing if the problem goes away. If it doesn't, I would suggest trying to contact mesa about the issue. Hopefully that's a little more helpful...
