Gear and Equipment
Metal Rig (Help me build!)
Gear and Equipment
10-19-2009, 09:01 PM
fowl2338
Posts: 119 - iTrader: (
I currently own an '87 Randall RG 80 ES. But i am looking for a bit more versatility.
Ok, I am looking for a tone that extends from:
Ozzy "No More Tears"--->AIC "Facelift"--->BlackLabelSociety--->Metallica "Master"-"Black Album" -->Pantera (althought I realize SS Dime sound won't be really attainable with tubes).
Option 1: OD-->EQ-->Legacy (Or X100B)-->Randal Jaguar Cabs
Option 2:
Preamp
-->TS100(or other somewhat inexpensive poweramp)-->Randall Jaguar Cabs
(I've been thinking about Peavey Rockmaster, Rocktron Voodu, ADA MP...)
Open to ALL advice/criticisms.
fowl2338
Find all posts by fowl2338
10-19-2009, 09:18 PM
Magical Muffin
Posts: 536 - iTrader: (
Re: Metal Rig (Help me build!)
fowl2338
Dimebag used Kranks, not sure which model, but their site will tell you.
And I wouldn't personally go for the Legacy, as the bands you listed (
BLS
Metallica
, Ozzy) is aiming towards more of a Marshall/Mesa territory. Maybe Engle?
What in particular is lacking on your Randall?
Magical Muffin
Find all posts by Magical Muffin
10-19-2009, 10:42 PM
hellboar
Posts: 221 - iTrader: (
dime didn't REALLY use kranks....he used Randalls. His sig model was still pretty much under production at his death, sure he had "made the switch" but he didn't really get much use out of it.
hellboar
Find all posts by hellboar
10-19-2009, 11:17 PM
fowl2338
Actually he only used the RG100ES/HT (MM-CFH, GSTK) and Century II (VDOP-FBD, 101Proof-RTS) heads. Warheads were on stage but apparently never used. And he definitely never used the Krank.
Reason I bought the head. Nothing lacking. Just not versatile.
My band's sound is looking to go a bit outside of the Pantera box. Incorporating heavy grunge, and possibly power/prog/more melodic stuff.
Mainly more tube sound.
fowl2338
10-19-2009, 11:26 PM
LonePhantom
Posts: 5,368 - iTrader: (
Reviews: 98
Check out the Blackstar Series One amps, nice heavy sounding tube amps with the ability to dial in US or UK tones, or anywhere in between.
LonePhantom
Visit LonePhantom's homepage!
Find all posts by LonePhantom
10-19-2009, 11:39 PM
ibby7stringer
Posts: 21 - iTrader: (
LonePhantom
+1 on that.....those amps do sounds great and they are fairly inexpensive.However metal rig....id have to say something like that Bugera 1990 Classic 120w...its made to sound similar to the Marshall 900 series and its a valve amp so theirs where you'll get that "tube" sound.....its fairly affordable i mean it goes for $450 on musicians friend.
http://www.youtube.com/watch?v=eFv-VBRrtlA
This is the review that sold it for me....plus youll be able to get the BLS,Dime,Ozzy sound out of this thing....i suggest you use the eq in the effects loop and the od in the direct signal path...that should be good....But then again thats just my opinion and a humble on at that.....
ibby7stringer
Find all posts by ibby7stringer
10-19-2009, 11:46 PM
fowl2338
LonePhantom
WAY to expensive. Don't wanna spend more than $700.
fowl2338
10-20-2009, 01:13 AM
Yousef
Posts: 378 - iTrader: (
Metal? AWESOME!!!
I suggest checking out some Peavey stuff! They can get real high gain without the real high price. Check out the 5150 (you see the combo version of this amp going on craigslist for $500 in atlanta and greenville,sc all the time). Or the XXX which is almost the same amp as the new 3120. Put a TS9 in front to boost for solos and ta-da you got some great versatility.
Check out the Peavey ULTRA head also.. they're great amps that are older and much cheaper.
If you want to go the
carvin
route, the V3 will probably be a better choice than the legacy for metal stuff.
Yousef
Visit Yousef's homepage!
Find all posts by Yousef
10-20-2009, 01:35 AM
hellboar
Yeah, the 5150 is a staple amp. Too bad they dont make them anymore, Eddie went all rogue or whatever. The newer 6505 line is supposed to be "the same" but I'm not so sure...
hellboar
10-20-2009, 12:23 PM
fowl2338
Well,
this guy
is apparently playing straight into a Legacy.. Hm
Anyone have a consensus on ADA MP's?
Peavey Rockmaster?
Rocktron Voodu Valve?
fowl2338
03-10-2010, 02:59 PM
Metalbucker
Posts: 48 - iTrader: (
Reviews: 9
fowl2338
Option 2: Preamp-->TS100(or other somewhat inexpensive poweramp)-->Randall Jaguar Cabs
Dude!!!, Keep your Randall RG80ES!, But Run Your Randall "CLEAN", And Try the New "All Analog" "
MXR Fullbore Metal
Distorton Pedal INSTEAD!
This Metal Pedal REALLY SOUND's RIPPING!, and So Responsive! w/ Really Wide Mids Control, Plus!, It Has Its Own Internal Noise Gate! For "Full On", BETTER than Randall & Dimebag Solid State Grindage. I mean, all the tones/bands you describe and mention, can be had with this pedal!, plus another cool trick is using a Boss LS-2 Line Selector Pedal and Setting it up for Two Overdrives/Distortions, One on Loop A, the other on Loop B, that way you just set em' Up exactly the way You want. Say Your'e using the Line 6 Uber Metal Pedal, on Pulverize, (Which Sounds Fantastic!), as your Main Rhythm Tone, on Loop A, and your using the MXR Fullbore Metal as Your Lead/Solo Tone, on Loop B! and then you just run em' Full On and just toggle between them with your Boss LS-2 Line Selector Pedal.and Obviously You can Set your Solo Tone Louder, & different Mids, than your Rhythm Tone, to Really Stand Out with this kind of Set up!
03:54 PM
Metalbucker
Find all posts by Metalbucker
03-10-2010, 03:19 PM
D.Vial
Just get a 5150/6505, Peavey XXX, ENGL, Mesa. 6L6 Hi gain amps, then buy a maxon 808 or a Ibanez Ts-9
I have the XXX and it's pretty metal
D.Vial
Find all posts by D.Vial
03-10-2010, 03:55 PM
whtwlf
Posts: 53 - iTrader: (
I like the pedal idea. Satch plays his amps pretty clean and gets the dirt through pedals for the most part.
Mind you the dirty channels on the JSX are pretty gnarly.
Especially if you like the Randal, cheaper to get some pedals and tweak the tone.
I have a Peavey Vypyr which I like but haven't played in any big rooms with, mine's all solid state but there are 60 and 100 watt versions with tube power amps in them that could be an option if you want modelling. Again I haven't heard one played in any sort of venue so can't comment on how they scale.
I've heard a lot of guys bring stuff to a pub jam that they think sounds fantastic in the bedroom but sounds all thin and nasty one you crank it with other instruments.
Cheers,
Shane
whtwlf
Visit whtwlf's homepage!
Find all posts by whtwlf
03-10-2010, 05:03 PM
D.Vial
The idea of getting a Maxon or a Ts-9 with a hi gain amp is getting a tighter sound, you must use the overdrive of your pedal turned down with the tone knob hi on your dirty channel
D.Vial
03-10-2010, 05:44 PM
LonePhantom
Reviews: 98
fowl2338
Check out the Blackstar HT-Venue series then. the 100watt head should be in your ball park budget. If there's not enough gain just add an overdrive pedal.
Check out official demos I've compiled on my blog.
http://www.lonephantom.com/?p=470
LonePhantom
aic
bls
carvin
metallica
preamp
how to build your own custom jem guitar
how much to build a JEM
how can i build my own tube amp
what metal is edge 3 tremolo made out of
how to build a jem
GMC build
andyt
11-30-2010
08:32 PM
My jem build
guitar-mick
07:07 PM
Who can build this for me?
Smitty
12:33 PM
My Build
LethalAe86TypeR
Tech: Setup, Repairs and Mods
07:39 PM
Edge/Lo Pro metal - Type of metal?
YngVaiTriani
07:01 PM
06:46 AM
