Gear and Equipment
Midi Footcontroller - need suggestions
Gear and Equipment
09-17-2001, 02:44 AM
revsharp777
Posts: 980 - iTrader: (
OK. *Here's the scenario. *I'm venturing back into guitar rack system territory. *Here's what I have (in order):
Furman Power Conditioner
Rocktron Chameleon
BBE 462 Sonic Maximizer
Rocktron Velocity 120 Power Amp
Now, I'm looking for a reasonably priced
midi footcontroller
that'll give me lots of flexibility. *I'd like to get the Rocktron All Access, but I believe it runs about $900 & that's just too much. *Any suggestion? *
revsharp777
Visit revsharp777's homepage!
Find all posts by revsharp777
09-17-2001, 03:47 AM
MadKeithV
Posts: 88 - iTrader: (
Midi Footcontroller
Behringer has a new footcontroller out that looks very promising. *It'll most likely be pretty cheap (all Behringer stuff is, at least here in europe), but it has a lot of very cool functionality. *Check out
www.behringer.de
, I believe there's a link to it from the front page.
Or else try the direct link:
http://www.behringer.de/eng/products...ns/fcb1010.htm
MadKeithV
Find all posts by MadKeithV
09-17-2001, 04:37 AM
jeffrey
Posts: 971 - iTrader: (
Midi Footcontroller
Try the Digital Music Corp. Ground Control.
I have one and am very happy. And it's not $900.
It's very flexable and I believe you can download the manual from their site. If you have any questions about it feel free to ask.
jeffrey
Visit jeffrey's homepage!
Find all posts by jeffrey
09-17-2001, 07:45 AM
gkelm
Posts: 1,564 - iTrader: (
Midi Footcontroller
I second the DMC GC...should be about $150 on the used market.
Greg
gkelm
Find all posts by gkelm
09-17-2001, 10:02 AM
cerealk
Posts: 2,428 - iTrader: (
Midi Footcontroller
ART X-15: an excellent pedal with two
expression pedals
built in.
check on ebay for one
Good luck!
Simon
cerealk
Visit cerealk's homepage!
Find all posts by cerealk
09-17-2001, 01:37 PM
one less than none
Posts: 376 - iTrader: (
Midi Footcontroller
depends what your needs are really .....
the all access is built like a tank but very expensive
the rolls are cheap and powered via midi and accept up to 8 CC pedals (hmmmmmm might be enough)
i also second simon's suggestion of the ART, and recommend myself the yamaha MFC-10 which has 1 built in CC and provision for 4 more
i've had one for years, dropped it, spilt beer on it, left it in venues ..... and it still comes back for more
one less than none
Visit one less than none's homepage!
Find all posts by one less than none
09-17-2001, 09:01 PM
spiro
Posts: 119 - iTrader: (
Midi Footcontroller
ART X-15 Foot Controller.... *I own 2 of them *and swear by them....
I also own a Roland FC200 MKII
Rocktorn all area and a ADA older controller...
spiro
Find all posts by spiro
09-18-2001, 06:10 PM
revsharp777
Midi Footcontroller
Thanks for all of the suggestions. *I'll definately keep them in mind. *I've decided to start checking prices for the Rocktron All Access. *Can anyone recommend a couple of GOOD online
music store
who carry these. *I've found a couple of Rocktron dealers, but they only carry the amps. *thanks.
revsharp777
09-19-2001, 09:19 AM
wyzenhymer
Posts: 82 - iTrader: (
Midi Footcontroller
Hey Rev,
*I have the same system you described, but with a Velocity 300, and was going for the Rocktron All Access, until I saw the ART X-15. Believe me, you want the ART!!! For the money, nothing will give you this kind of access.
* *Good Luck,
G.M.
wyzenhymer
Visit wyzenhymer's homepage!
Find all posts by wyzenhymer
09-19-2001, 08:31 PM
spiro
Midi Footcontroller
I agree too....
I have both but the art is the bees knees....
spiro
09-22-2001, 06:56 AM
revsharp777
Midi Footcontroller
OK, you convinced me to go with the ART X-15. *I ordered one today. *Thanks for all the help. *Now, hopefully I'll get all of this newly acquired rack gear to work together since I'm an idiot when it comes to processors. :biggrin:
revsharp777
09-22-2001, 09:39 AM
bammbamm
Posts: 4,134 - iTrader: (
Midi Footcontroller
Once you set up all the MIDI channels to respond to your controller, you'll be pleased as punch !
Whats nice is you can assign the expresion pedals to control almost ANY parameter that can be affected by a midi signal, ie: lengthen the tail of a reberb out of a solo, increase the depth of flanging, rate, I used this one to simulate a leslie cab type sound, kinda kewl.
Much versitility !
Enjoy, let me know if you have any ?'s I have changed my setup so many times and the X-15 is still at my feet controlling it all. Have fun !
Bamm
bammbamm
Visit bammbamm's homepage!
Find all posts by bammbamm
09-27-2001, 10:35 PM
rlintz
Posts: 466 - iTrader: (
Midi Footcontroller
I also have an Art X-15 which I scored for under $200 on eBay long ago. *I love it! *Only complaint is I wish the expression pedals had toe-switches and the mechanism for controlling the expression pedals is kinda flimsy (not the pedals themselves). *There's a little piece of plastic underneath that appears to have a bar-code like design on it. *I had a cable get tangled up underneath the pedal once and bent the plastic piece up pretty badly - still works but doesn't leave me feeling real secure.... *Nowudameen.
rlintz
Visit rlintz's homepage!
Find all posts by rlintz
10-04-2001, 03:59 AM
spiro
Midi Footcontroller
I have about 6 spare bar codes as you call them they only cost about $1 each * very easy to change.....
spiro
10-08-2001, 06:56 PM
Shane Regal
Posts: 133 - iTrader: (
Midi Footcontroller
Rocktron also makes a cheaper foot controller. *It's called the midimate. *I had no problems with mine. *It works great, and even has an input for a continuous controller/volume pedal.
Shane Regal
Visit Shane Regal's homepage!
Find all posts by Shane Regal
expression pedal
expression pedals
furman power conditioner
midi controller
midi foot
midi footcontroller
music store
power amp
rack system
rocktron chameleon
rocktron velocity
sonic maximizer
volume pedal
recording guitar through midi card?
how to use midi in boss gt5
how petrucci connect midi in triaxis
how to connect rockman midi pedal to marshall jmp-1
12:58 AM
